Man theres alot gripes with me but I cant gripe back so whats the difference?
Project 41" Sprintcat!
Sanded the fins and the aluminum tubing for a good thermal transfer bond. Rolled them in the thermal epoxy and now they are nice and tight. I can pick up the whole setup by any of the tubes without worry of bending. Seems that was the right length to keep them from being weak.
I'm so tempted to put a coat of paint on it, but it will only insulate the heat sink and reduce its efficiency.
The plan is to split the water from the dual pickup rudder coming in across all 6 tubes and a separate set for the motors. Since the pickups are 1/4" there should be adequate flow for this many dispersions. If not, I can loop through the ESC with one line per side, but I don't anticipate any flow issues.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
don't take it personally, you do have good advice to give when you so choose, but seriously just edit your posts if you forget something the first time aroundOriginally posted by Xfactor View PostMan theres alot gripes with me but I cant gripe back so whats the difference?
Anyways to get back on topic, Fighter the cat is looking pretty good thus far and I like those cooling plates
Can't wait to see it done
Thanks! I know it's not a world class project, an extreme setup or even competition level, just having a bit of fun in the garage.Originally posted by supafastsupra2 View PostFighter the cat is looking pretty good thus far and I like those cooling plates
the admins/mods have no favorites or would ever speak on a memeber in that wayOriginally posted by FighterCat57Today, 08:10 AM
This message is hidden because Xfactor is on your ignore list. The Admins have designated him village idiot.
Please refrain from these type of comments"A quick temper will make a fool of you soon enough."
Time to make some motor mounts tonight!FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Build your boat young man. I was merely a brotha trying to help u out already been where youre going trying to give you the real deal but like I said was trying to help you. As far as the cat out of the bag Im black too thats great man.I said I wont comment on your build cause u cant seen to take a joke which really was sound advice but id appreciate if youd keep comments about me out your post esp If I cant say nohing to ya to help ya.You got cash to spend and no idea what to spend it on . A retailers dream. I was only trying to help u young man believe what you may.
So where you at with motors? Any decisions yet?
The heatsinks look awesome. Thermal Mass for the win!
When you drill the hull, cover the drilling areas with masking tape if you are not already doing it
. Also makes marking the holes a lot easier with something to draw on.
I find it absolutely exciting working with a freshly painted hull. Delicate and fragile.Originally posted by crabstick View PostSo where you at with motors? Any decisions yet?
Masking tape is an excellent way to help prevent chipping and allow marking. Although the caution is that the tape goo not stick or remove the fresh paint!
I use the blue painters tape and sometimes clear vinyl, but the vinyl does tend to stick pretty well.
=)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Say fighter, check these beasts out http://www.leopard-model.com/product...ionID=01020202
I think you can get 2 of these110A 5500 watt beasts for the price of 1 Neu 1527. I like the 1344 kv on 8s... 39,782kv on each side... sounds sick to me...I might have to get into a large cat project myself after seeing these 7 HP monsters!!! LOLLast edited by RCKong; 06-22-2010, 02:48 PM.
someone priced those big Leopard motors to me at $225 each, and I thought that was kinda highOriginally posted by RCKong View PostSay fighter, check these beasts out http://www.leopard-model.com/product...ionID=01020202
