HK Osprey/Delta 39' copy
  • v-spec
    • Jun 2009
    • 1046
    #46
    If you want to sell that Motor and ESC i would love to buy it if it's not to pricey. I should be getting my brushless elam from ebay tomorrow and I need something for it.
    • TwzteD
      • 95
      #47
      well`the motors are going for 90+ and esc are 75+ both need to be imported so id sell them both for 165 shipped, but i need a few days to think about it and see
      • v-spec
        • Jun 2009
        • 1046
        #48
        Let me know, im intrested.
        • RIPFENCE
          • Sep 2009
          • 1577
          #49
          definately sell the gear and then upgrade or use the gear in a smaller hull..that hull and hardware would be a good base to build on..thats the problem with these type of rtr they are not really set up for great performance..you can only expect so much i guess..it seems to be a decent value otherwise..i am pondering about getting one and dumping a big neu into it
          "FE" STANDS FOR FRUSTRATING EXPLOSIONS
            • 9481
            #50
            The motors are going for $85 to $88 shipped
            • TwzteD
              • 95
              #51
              If I buy the neu 1527 what kinda voltage am I lookin at? Would a turnigy 180a eac it am u forced to use a hydra 240
                • 9481
                #52
                depends on the wind.. you could go 4s or 6s and some have run the T180 esc with great results on the 1527
                • Rumdog
                  • 6667
                  #53
                  A 1527 1.5d on 5s2p with a 240lv would make it rip!
                  • TwzteD
                    • 95
                    #54
                    ok thanks guys guess ill have to start looking for a used motor with a 5 mm shaft what kind of 1527 would be best if i did get the t180 esc?
                    • TwzteD
                      • 95
                      #55
                      will the turnigy Marine 180A be able to handle a nue 1527 1y? can some one please lemme know
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        #56
                        My answer would be no. I have a T180 running a CC 1515 and it gets hot.
                        I have a 1527 that I'm running with a Hydra 240. Pretty cool setup. Jeff makes special 8mm couplers and wire drives that work great with it.
                        • bustitup
                          • 3072
                          #57
                          My answer is yes it will...watch your temp
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            #58
                            I've not tried it, so this might be good.
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1743
                              #59
                              If you go 580 I have one. ESC (180a) temps with this motor on 4s2p and m447 under 120. PM me for details if interested.
                              • bustitup
                                • 3072
                                #60
                                Just to clarify
                                I have run 180t on 6s2p with scorpion outrunner
                                WATCH temp
                                I trust the 180t more than Any Hydra
                                .......jmho
