GENESIS (36''/935mm) Twin setup suggestions
  • Alfa Spirit
    • 2183
    Hi,
    in a few days my new GENESIS hull will be at home and i need your help for a twin setup.
    2 x 3S serial 22,2V
    2 BL motors 1700kV
    Any other setup suggestions?
    Thanks
  • Alfa Spirit
    • 2183
    Thank you for your help guys,
    Batteries : 2 x 5S 5000mAh
    ESC : 2 x Hobbywing 180A (Turnigy)
    Brushless motors : 2 x NEU 1512 1.5Y / 1850kV
    Unload RPM : 34225
    Upgraded powertrims from Raceboats.de
    • Jeff Wohlt
      • 2740
      Nice extention idea on the prop shafts. Any reason a new strut tube can't be put in those?
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • Alfa Spirit
        • 2183
        There are 3 reasons:
        Powertrim must be long for propeller being out of the hull, flex and strut are strongly assemnled and I want to use bullet nuts, I like that
        • Alfa Spirit
          • 2183
          Here' s a picture, easier to understand, extensions are very well made and very light
          • mudl
            • 196
            Hello
            i think that this does not work as you plan it.The rotating part is to long.The prop is to far away from the last ball bearing of your drive.I Think you have many vibrations on the shaft,and the ball bearing brokes very soon.The best thing is to make the last step of the boat longer for mounting the drives.(see picture)
            bye
            mudl
            • Alfa Spirit
              • 2183
              May be but those powertrims from http://www.rc-raceboats.de/shop/lng/.../16-props.html look very strong, they are very well made with high quality materials. I made a mistake with the extensions lenght, my friend will build an other short pair 18mm long. There are 3 ball bearings in the strut. Those custom made parts fit perfectly the Raceboats.de stingers, really. I hope that will work fine
              • Alfa Spirit
                • 2183
                I put a bulkhead in my HOTR cat hull and I want to do the same for the Genesis. there is foam into the front of the hull
                If somebody did this on a Genesis I' m interested, thanks
