Couplers
  • speedsport
    • Mar 2010
    • 49
    Couplers
    Any one know where I can get a 2.3mm motor to .098 flex coupler?
  • Jeff Wohlt
    • 2716
    Not flex but I can make one that is setscrew. You might find one across the pond but ti woud be metric on the 098 end probably.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • speedsport
      • Mar 2010
      • 49
      Is there any reason that I could not use one with set screws for the flex shaft? As far as a metric one do you know who sells them?
      • JimClark
        • 5902
        I might have a couple of Jeff's I would be willing to sell. I need to check I ordered by mistake
        Billy Graham
        • Jeff Wohlt
          • 2716
          Thats right, Jim! Perfect. Just solder the cable end and you are fine. I can tell you one thing...Ed Hughey has set more records than anyone and has only used setscrew couplers all his life.
          www.rcraceboat.com
          • speedsport
            • Mar 2010
            • 49
            sounds good.
            • detox
              • 2310
              What is the trick to prevent set screw coupler from slipping on a .078 drive wire. Do you have to file flats on the wire?
              • JimClark
                • 5902
                OK just checked and I do have two never used (I ordered 2.3mm when it should have been 2.23mm). Jeff made them and there are 4 set screws for the flex and two on the motor shaft side.
                They are 1.25 inches long and .375 inches diameter.
                I think I paid $10.00 each. How bout $15.00 shipped for the both of them
                Let me know
                Jim
                Billy Graham
                • Jeff Wohlt
                  • 2716
                  Yep...flat spot on the wire to set the screws down on then you tighten the opposing set screws as well. Make sure you hit the flat spot. I file mine out beyound the coupler so I can see the flat area when setting the screws down.
                  www.rcraceboat.com
                  • speedsport
                    • Mar 2010
                    • 49
                    I just double checked the motor and the flex shaft. The motor comes out to 2.26mm and the flex comes out 2.4mm. so 2.3 should work for the motor but I don't know about the flex shaft. Oh also I'm only looking for one.
                    Thanks every one
                    • JimClark
                      • 5902
                      you would have to drill out the flex side of what I have. I am only selling both I have no need for them. it is up to you. You would be better off just having Jeff make you exactly what you need.
                      Jim
                      Billy Graham
