Rudder mount break-away hinge with spring latch??
  • OshkoshMono
    • Apr 2010
    • 207
    Anyone come up with something like this yet? Or know how to make one with out a CNC machine..... I just think there has to be a better way (or cooler way) than a snap off bolt. Maybe....???
  • kookie_guy
    • 900
    ball nose plunger with a dimple in the rudder. You can set the tension on these too.
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    • HappyOne
      • 185
      My hydro came with a bolt in the top part of the rudder bracket but a cable tie through the bottom hole. It you smack something with the rudder the cable tie breaks and the rudder swings up and back. Easy to fix and seems to work. I have had it do that at least once before.
      You can't see the cable tie in this picture but you can see the top bolt
      Grand River Marine Modellers, el Presidente
      IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
      • OshkoshMono
        • Apr 2010
        • 207
        Ok, Those give me some ideas. Thanks guys. I was thinking the breakaway bolt went in the transom, guess I was confused. Makes more sense now.....ha.
        • JimClark
          • 5913
          I use a nylon 2/56 screw for my breakaway rudders
          Billy Graham
          • CornelP
            • 793
            That's what I did to a Graupner rudder: nylon bolt plus a spring. Works perfectly to get your boat back.
