Project Genesis!
  • Jacked1
    • Jun 2010
    • 772
    #301
    Originally posted by FighterCat57 View Post
    Friday. Have a half dozen of them. Think I'll put a pair of them in a Genesis to see what they can do.
    I stuffed a pair of 1717's in a Daytona (Genesis) today. Used the 50mm TwinCat Motor Mounts I had made. He he. Twin 1717's? Can you say SAW Boat?
    I was 2 sec away from getting 2 1717's for mine on thier black friday sale but thought they wound't fit with jackets in there but the watercooled mounts and some fans would prolly be enough! You should put those bad boys in there! :D:D
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      #302
      Yeah, I just posted a WTB for another 1717 air. I think they'll stay cool enough.
      • Igoreski
        • Apr 2010
        • 77
        #303
        37" Daytona.
        I will be building the Daytona which is similar to this and I have a couple questions.I will be running counter rotating props and need to know if the stingers have to push the prop past the back of the boat to work right.I think prop rotation will not be a problem but my stingers have the prop 1" short of clearing the back and are 75mm from mount to prop.I found some 110mm ones on Fighter Cat web store but they are out of stock.
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          #304
          Pre order them. Should be ready in a few weeks. :)
          • Igoreski
            • Apr 2010
            • 77
            #305
            I take it you tried the short stingers and they did not work.If I get those should I use the 3/16 flex cable or are wire drives better.
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              #306
              Cables work well. The Wires have less resistance and should yield better top performance.
              HK will have this version soon. It's a twin genesis with the short 4mm stingers.
              I've tried to get them to use the longer stingers, but they don't see a reason for it. They want to use 4mm shaft, 38mm props on this one.
              • tunnelvision
                • 685
                #307
                Hey FC,
                Can you use the wire drives on a single setup or is there too much bend in the stuffing tube?
                Thanks.
                Go Fast...Turn Right...
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  #308
                  Originally posted by tunnelvision View Post
                  Hey FC,
                  Thanks.
                  I've run the 078 wires right in the stock tube.
                  I've only broken 1, but noticed that it was binding when it broke. I had re-greased it and didn't adjust it correctly and it was causing a bind in the bend.
                  I have some available. Not sure if Jeff is still doing the 4mm drives or not.
                  I really like the wires, because there's no thrust twist and less wear on the motor bearings. No need for thrust bearings.
                  • tunnelvision
                    • 685
                    #309
                    Cool, thanks. What size would fit in the stock Genesis?
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3480
                      #310
                      078 wire with a 4mm size prop shaft. I think they are 12.5", but get the 13" and cut it to length. Grind in a flat spot for the prop dog and you're good to go. I also like to scuff the end of the shaft that goes into the coupler for a little added bite.
                      • tunnelvision
                        • 685
                        #311
                        Great, thanks for the tips!!
                        • Igoreski
                          • Apr 2010
                          • 77
                          #312
                          Stingers.
                          Yea the more I looked at it the more I realized that the short stingers would be problematic.The turbulence from all that water being thrown into that small cup shaped area would cause drag and cut down the great roosters that twin drives throw.I ordered the new 110s and we will have to figure out wire / cable drives and couplers later.I have been using the ones with 6 set screws without problems but are the collet couplers better for any reason ??
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3480
                            #313
                            I'll have cables when the hardware is ready.
                            OSE has 3/16" cables/stubs that would work as well. Lots of choices.
                            • Alfa Spirit
                              • 2131
                              #314
                              2 x CC1717 in a Genesis hull? They are big motors
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3480
                                #315
                                Yeah, but they fit. (sans water jackets)
