Project Genesis!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    #181
    I do think since this hull is narrow it would be more stable as a twin!
    • mudl
      • 159
      #182
      Originally posted by Alfa Spirit View Post
      This is a very nice job
      I don' t understand the setup 7S for two combos esc+motor, right?
      Hello
      i drive only one 7 s Lipos.
      I power both motors with the one pack,because 2x 7s packs are to heavy
      greetings mudl
      • Alfa Spirit
        • 2131
        #183
        Thank you for reply.
        I have 3S batteries for my HOTR cat (4 sets), I can use them with the Genesis: 6S 5000mAh for two motors, but I think that run times will be short
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          #184
          Just an update, today's first runs with SBEC on 4s, 447 ran 42.5 MPH
          Run time was about 8 minutes, but I brought it in to check temps. Nothing too hot to touch. Wires were a bit hot though.
          Using 5mm bullets and 10 gauge wire.
          Next step, m445 and 6s
            • 9479
            #185
            Sweet!
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              #186
              Update:
              Couple runs in this AM. Nice calm freshwater pond.
              2 x 4s 5k 40c packs, 8 min runtime (15.2v left in pack after run- I pulled it in to check temps)
              m445, 43.6 mph, nice smooth and straight. Dropped the strut down and she straightened up.
              Temps all under 100F
              I forgot the new 6s packs, so will have to give them a try the next time out. Might even drop the prop size to a 440 to help assure low temps and a good starting point for 6s.
              • Make-a-Wake
                FE Rules!
                • 5554
                #187
                Does anyone have the programming guide to the stock Genesis ESC? The download on Hobbyking comes up blank...............??? Anyone know what brand it is.............??
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  #188
                  Yeah, I think it's in Alfa's thread too.
                  • mudl
                    • 159
                    #189
                    Hello
                    normaly it is this esc
                    HiModel GX Seires 125A 3-7S Brushless Electric Speed Controller Type GX-125A from manufacturer HiModel, in category Brushless Speed Control (BL ESC) - Air/ Helis, Electric Speed Control (ESC).
                    bye
                    mudl
                    • Make-a-Wake
                      FE Rules!
                      • 5554
                      #190
                      Thanks guys...............I think thats the one i have, for some reason i cant open the one you just posted Fighter, i dont have the updated "disc" its telling me, is the file here the same?
                      If so, a i cant get out of setup mode..................... Thanks Fighter and mudl.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3480
                        #191
                        Yeah, same file. I know I had to do some servo reversing to get the throttle to calibrate. I don't recall all the issue, but remember I did have some problem and ended up using 70/30 trigger with the throttle trim all the way to one side.
                        • mudl
                          • 159
                          #192
                          Hello
                          here are some new pictures of my genesis.
                          Drives and Ruder is mounted.Inside one Motor is mounted and the Lipoholders.
                          bye
                          mudl
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            #193
                            Thanks Fighter, I am using this in another boat by the way..........but, I did reverse the throttle input, all i can get out of it is a wide open reverse sometimes??
                            Do you know how to get out of setup mode?
                            Thanks a bunch, just trying to use a cheap piece of equipment i got for little $.
                            • Alfa Spirit
                              • 2131
                              #194
                              Originally posted by mudl View Post
                              Hello
                              bye
                              mudl
                              Nice job
                              This is a Hopf rudder, right?
                              • mudl
                                • 159
                                #195
                                Hi
                                yes the rudder is from hopf
                                bye mudl
