Darin's Top Speed 2 FE Conversion...
  • bigwaveohs
    • 606
    #211
    Vs-1
    Joey Bro, I feel your pain. After building 2 TS-2's & having lots of trimming problems, I built a VS-1. It's faster & handles perfectly; corners FLAT. With all the work you're about to perform, why not just put the effort into a VS-1 ?
    OTOH, I'm going to rig the second TS-2 [JS-2] for an attempt at the NAMBA SAW P-OPC record {@60 mph] this year. Actually the VS-1 would be a better boat for SAW, but I don't want to take a perfect heat race boat & change anything.
    As an expert with the VS-1 hull, does it need "stumble blocks" to help cornering? I'm going to be setting one up here in NoCal.
    Thanks
    I let the dogs out...
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      #212
      Thanks
      The VS-1 kit has the stumble blocks already bonded to the hull. First time I've been called an "expert" - you must have me confused with Darin or someone like him
      Set up correctly, the VS-1 totally rocks !
      • cybercrxt
        • 2926
        #213
        Peter, The VS1 comes with the stumble blocks already factory mounted. When you get my hull and get the motor and electrics dropped in, you will see what this boat can do! It turns on a dime! Mike
        • bigwaveohs
          • 606
          #214
          Excellent!
          • bustitup
            • 3072
            #215
            opinions on this lower unit please....is a cavitation plate a must?
            • bustitup
              • 3072
              #216
              no one have an opinion on no cav. plate?..........is that a no no.......really
              could use some feedback on this k&b modded outboard
              you can hurt my feelings i can take it
              • NativePaul
                Greased Weasel
                • 2770
                #217
                I've never used one so cant be sure but I would have thought that if you have it mounted up high so it operates in surface drive mode I cant see how a cavitation plate would be of any use.
                • bustitup
                  • 3072
                  #218
                  Makes good sence
                  • properchopper
                    • 7708
                    #219
                    I seem to remember a discussion of this on the IW outboard forum, but I can't locate it. If you post the question there I'm sure you'll get some answers. What I do know is that quite a few REK users have trimmed it off to run larger diameter props with good success, apparently.
