Darin's Top Speed 2 FE Conversion...
Andy,Originally posted by andym View PostDarin it looks bloody great mate, cant wait to see how it goes. I am having trouble with mine wanting to go upside downs in fast tight turns because the xl feigao motor sits to high and is to heavy. If the sv motor works good might try the ammo motor. As is much smaller in size and wieght to the xl.
I also lowered the motor down on the lower leg as FAR as I could... I was able to get it about 3/16" or so lower than it was originally when I bought the unit... Just took a lot of measureing and test fitting to get it just right... Measure twice, cut once, and all that...
Leave a comment:
Leave a comment:
Well... I get a little further each day... Just have to install the steering rods and add the cooling lines to the lower unit, and I should be just about ready...
The Hi-Jack 3.5 is WAY too cool, in my opinion!!
I also have one of these new motor mount blocks coming from Ray Fuller... There is a motor cover being developed that isn't done yet, but that will attach to this block and give it more of a "scale" look.... That ought to wrap things up nicely...
More to come...
Leave a comment:
It IS a Jack Plate!! "Hi-Jack 3.5"...Originally posted by SJFE View PostYa know if I didn't know any better I'd say it was a jack plate. Kinda look like one.
Leave a comment:
See now thats what I'm talkin bout. Anodized shiney stuff. Nothing I like more on a boat. Nice Peice of hardware man!!!!! Ya know if I didn't know any better I'd say it was a jack plate. Kinda look like one.
Leave a comment:
Well... I have Steven sending me an Octura 3.5 mount, and Brian ordered me a Dubro 3.5 mount with his order...
Awh the Heck with it... SCREW the extra weight... I just made THIS purchase and it's going to LOOK COOL.... BLING!!
Might not be quite as fast, but it will look DAMN good when Brian and the others go blowing past me!!
Leave a comment:
Only one way to find out! Your's looks really nice... I figured I'd try it this way, at least up to the point where I get the motor mounted and can actually check the CG... If it's off, I'll revise my plans accordingly... I haven't ruled out cutting out the deck and just building a full-length box... but I wanted to see if I could make it work with this less intrusive method first... You may be right... It may be too far forward...Originally posted by Fast Guy View PostI'm wondering if your weight might be too far forward. The TS2 doesn't like to stray too far from that 9 1/2in balance point. Thats a good idea for the box. I extended my box so I could lay both my batteries on the bottom. The boat handles much better that way.
But then... With the nitro ones, the guys are having to add 5-6oz of weight to the nose to get them right... so we'll see... I should know shortly... Just have to get the motor mounted...
Leave a comment:
Leave a comment:
4S1P of 5000 mah Poly RC Lipo cells drops right into the front box with room to spare... I lay them in there on edge, but they come in and out and fit fine...Originally posted by kck741 View PostWhere are you going to put the batteries are you going to stack them?
Leave a comment:
Leave a comment:
Here are a couple more pics, showing the second stock radio box, modified and attached to the unmodified stock box... Batteries should go in the front, rx and steering servo in the back... ESC will sit on the rear tray where the fuel tank was meant to go... We'll have to see if I can work out the 9.5" or so CG with this arrangement...
More to come...
Leave a comment:
Darin you are the rattle can KING. I am going to hunt down some of that expensive mask you use and have a go @ the jolly.
Leave a comment:
ESC - Cooling Plates...
Hi Guys,
Just thought I'd show you the cooling plates I just fabbed for my SV27 ESC for this project... I needed something much thinner than the factory ones, and I think these will work nicely...
The factory casing is just black anodized aluminum extrusion with the ESC inside and potted on either end, so I cleaned up the top and bottom, applied a little heat transfer compound (like you'd use on a CPU heat sink or similiar) and then used some high-temp tape I have (this happens to be "Boeing" quality for use in composite layup autoclaving...) to secure it all together... I think this may actually work better than the stock setup... It definately contacts the surface better... Not any heavier either...
Oh, and a BIG THANK YOU to Andym for sending me another factory radio box... I got it today and it's going to work very well I think...
More to come...Attached Files
Leave a comment:
Leave a comment:
