ML Boatworks- 30" P-spec Tunnel Build another new one!
  • bigwaveohs
    • 606
    Didn't see anything in the IMPBA Rules about ESCs...did I miss something?
    I let the dogs out...
    • Chilli
      • 3204
      Nope. There are no rules pertaining to ESC's in the rule book. In addition to the IMPBA rule book, IMPBA clubs and districts can develope their own rules. The Spec or limited classes that many districts have run using the UL-1, SV27 and BJ26 motors are not in the IMPBA rule book. They are district/club classes and some districts have ESC rules for these classes. I believe NAMBA does have classes using these motors and do have rules pertaining to controllers but I believe there are plans to remove them. Hopefully someday, IMPBA will adopt these rules on a national level.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • bigwaveohs
        • 606
        Originally posted by Nautiboyz View Post
        Nope. In addition to the IMPBA rule book, IMPBA clubs and districts can develope their own rules. The Spec or limited classes that many districts have run using the UL-1, SV27 and BJ26 motors are not in the IMPBA rule book. They are district rules. Some districts have ESC rules and some don't. I believe NAMBA does have classes using these motors and do have rules pertaining to controllers but I believe there are plans to remove them.
        NAMBA rules do not specify ESCs; just motors and battery voltage/capacity limits. As you indicate there are sometimes also "spec" classes (P-spec OPC) which refer to ProBoat, Aquacraft (UL-1, SV-27) and other "spec" motors that come with the RTR boats. This keeps costs down.
        • egneg
          • 4759
          Originally posted by cybercrxt View Post
          Chuck, I will definately let you know about what I need done for a prop. Once this rain clears out, I will hit the lake again. I have to cut out different stumble pads too. I am working on painting an 1/8th scale FE Miss Circus Circus I built for a guy this week, so that is my #1 priority unfortunately! Mike
          No Problem ... when ever you are ready Mike.
          IMPBA 20481S D-12
          • Chilli
            • 3204
            #35
            My bad Patrick. I read on IW that the P-spec tunnel rules used at the World Tunnel Championships and that I adopted into IMPBA D12 were taken from the NAMBA rule book. I just looked at the NAMBA rule book online and could not find it.
            Mike Chirillo
            • Doug Smock
              • 5359
              #36
              Those were authored by a NAMBA member. The CMB adopted them.
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
