Project Apparition!
  • NOZ69R
    • Apr 2010
    • 42
    #196
    Originally posted by FighterCat57 View Post
    This is the single motor model. I've changed the motor and ESC to a Turnigy 180 and a Castle Neu 2650. I run twin 3s packs in parallel. I also sometimes do the same with two 4s packs and a smaller prop.
    I'm just running for fun and don't mind the extra weight of running in parallel. If you're running for speed, series is the way to go. Much lighter configuration. With the twin motor model, I don't know if there's enough speed to warrant battery placement in the nose forward of the motors. That moves the COG pretty far forward.
    Hope this helps.
    Thanks Fightercat57,
    It is the single and I too will be only running for fun & have a couple of 3s 3000's from my planes that I can use until I recoup my play money. I guessed that running the batts down each side gives you better control over CoG.
    Also when measuring CoG do you start from the transom or the bow?
    Cheers
    The older I get the BETTER I was..
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      #197
      Cheers
      Twin 3s should give you some good run time with the stock setup.
      Measure forward from the sponson transom (where the stingers mount to the hull)
      HTH
      • NOZ69R
        • Apr 2010
        • 42
        #198
        HTH
        Again thanks,
        Can't wait to get her in the water.
        Cheers
        • NOZ69R
          • Apr 2010
          • 42
          #199
          I'm stuck
          Trying to set up the CoG and with the batts (3000 3S's) right at the very back and measuring from where the strut mounts to the hull the CoG is at 11".
          Any idea's.
          Cheers
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #200
            I'm stuck
            Any idea's.
            Cheers
            How about a photo of the inside of the hull and a photo of the measuring tape in place? Maybe something we can spot.
            • NOZ69R
              • Apr 2010
              • 42
              #201
              Here's a photo of where I'm am at the moment. Also note that 1 battery is out of the boat as i'm charging it.
              Cheers
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                #202
                Cheers
                Have a look at page 15 of this link: http://www.venom-group.com/mmVENOMGR...S%20Manual.pdf
                There's an item called CG range. I want to make sure this is what we are measuring.
                • NOZ69R
                  • Apr 2010
                  • 42
                  #203
                  Thanks FighterCat57,
                  Just read the link, my starting point was NO where near it, that was why I was getting 11".
                  All good now.
                  Cheers
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    #204
                    Cool. Let us know how it goes!
                    • NOZ69R
                      • Apr 2010
                      • 42
                      #205
                      Just come back from her first outing..set CoG at 210mm (8" 1/4') and ran nice but maybe a little wet.
                      On 3S it seemed slow... motor and ESC cool to touch so. Cant wait till my new batteries turn up so I can run 4S.
                      Very happy and looks so cool in the water.
                      Cheers
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        #206
                        Just an update on my Apparition build, Jeff W is making an 078 "Step Up" shaft for this bad boy.
                        The water leak was due to the nylon washer being too large and too loose. The prop dog needs to be snug against the teflon washer on these 4mm hex cable setups.
                        PSA- If there is cable slack, like on normal cable/shafts, they will leak grease into the hull.
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #207
                          Ran a great run today, 7 minutes and a top speed of 44.7 on 3s2p 10k 25c with an x440 Sharpened & Balanced prop. Plenty of battery left, had to pull in due to a steering servo failure.
                          It ran so cool and soooo smooth! Temps all about 100 after the run.
                          The x445 is too much prop and usually ends up putting the ESC in low voltage mode within a few seconds, so would like to try an x442 next and see how it goes.
                          It goes like a bat out of hell on 4s, but that's asking way too much of this cheap drive system. I know it wouldn't last long that way.... So sticking with 3s2p and not going for any speed records. =)
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3784
                            #208
                            Some updated photos of the cat;
                            The epoxy patch of the right sponson nose has held up well! That was quite a hit. (read up in the thread for photos of the carnage)
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              #209
                              Wow, I'm a bit confused on this one!
                              She's getting up to 46mph on an x440 prop, but sucking two full 3s 30c 5000mah packs to the LVC in less than 4 minutes!
                              The temps are a bit confusing too. The motor comes in at about ambient temp, 80-90 and the ESC around 110-120 and the batteries about 120. I don't have an amp meter big enough to monitor the amp draw on this setup but just want to get a head check, does that seem right?
                              The drive spins freely (it's a wire drive) and there aren't any heat issues. It just sucks them down fast.
                              • suckmywake
                                • 255
                                #210
                                Originally posted by suckmywake View Post
                                Here is some data from running my HOTR cat with different motors and props. My set up started with an ARTR HOTR cat. Twist was removed from hull. The sponsons still have some angle. I added a layer of 6oz fg cloth to bottom as far forward is I could reach. I added another layer around motor mount. The front was foamed. The strut was drilled out for SV type bushing and I am running .78 piano wire drive. The strut is set at gap of 1/8” above sponsons. The COG is 8.5” from sponson end. I run 6s1p on 2 Turnigy 3s 5000mah 35c/45c batt. All run were with same batts. The esc is 200a Himodel type w/bec. (ESC setting 0deg timing and PWM 8k on all runs)
                                Motors
                                Feigao 13xl 1339kv
                                ARC 36-55-2 1400kv (This looks to have wye windings)
                                Neu 1515 1.5y 1500kv
                                ARC 36-75-1 1680kv (This looks to have wye windings)
                                ...................................( .... @ speed indicated ....... )
                                .........Motor......MPH ... RPM ... Amp ... Volts ... Watts ... Peak Amps
                                X440
                                ... ARC 1680kv... 55 ... 35046 ... 74 ... 23.46 ... 1737 ... 139
                                X440/3
                                ... ARC 1400kv ... 51 ... 28409... 55 ... 23.80 ... 1318 ... 106
                                ... Neu 1500kv ... 53 ... 31250 ... 65 ... 23.29 ... 1521 ... 128
                                ... ARC 1680kv ... 59 ... 34722 ... 74 ... 23.66 ... 1754 ... 153
                                X442
                                Feigao 1339kv... 52 ... 28089 ... 58 ... 22.68 ... 1325 ... 109
                                ...ARC 1400kv ... 52 ... 28190 ... 55 ... 23.81 ... 1326 ... 110
                                ...NEU 1500kv ... 59 ... 30737 ... 80 ... 22.98 ... 1844 ... 137
                                ...ARC 1680kv.... 64 ... 33783 ... 85 ... 22.77 ... 1945 ... 166
                                Temps after running 1000mah
                                Feigao 1339kv..... Motor 106 F.......ESC 102 F
                                ... ARC 1400kv .... Motor 87 F.........ESC 99 F
                                ... NEU 1500kv .... Motor 117 F ......ESC 125 F
                                ... ARC 1680kv .... Motor 114 F...... ESC 121 F
                                Temps after running 2000mah
                                ARC 1400kv .... Motor 125 F ..... ESC 120 F
                                ARC 1680kv .... Motor 125 F ..... ESC 160+ F (HOT)
                                Notes on temp.
                                Feigao motor temp. continued to rise up to 140 deg. F just sitting. I take this as stator temp is way higher than the can temp. I never trust can temp on 2 pole motors. I always do 10 second finger test on end bell of all motors.
                                Neu motor was run with silicone SV type cooler. Not the most idea cooler. This is all I could fit with motor mounts.
                                The thing I found most interesting was the feigoa peak amps was lower than all other 4 pole motors. I always thought a 2 pole had a higher peak amp load than a 4 pole.
                                Another thing I find very interesting is that for any given speed and prop/motor combo the watts were about the same. So for the boat to do 52mph is around 1300 watts. If the speed goes up to 60mph the watts goes up to around 1800 watts. If the speed moves up to 64mph the watts go up to 1950 watts. This does make sense because a watt is basically Horse Power. 746 watts = 1 HP
                                So if your boat is in mid 40’s mph I would think your watts is around 1100 to 1200 watts. If you divide your watts by your voltage you will come out with you amps.
                                Watts=Volt * Amps or Watts/Volts=Amps
                                1150/11.1(3s) = 103 Amps
                                So I would guess your amps draw is around 100amps at 45mph with spike peaks close to doubling this.
