School me on 55" Twin Cats
  • crabstick
    • Jul 2008
    • 955
    sprintcat sprintcat sprintcat
    Matt.
    www.rcboats.co.nz
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      Originally posted by Rumdog View Post
      bad handling. Similar to the blackjack 55. Also too big for your motors.
      It's been established, I will need bigger, better, faster, more motor.
      link link link!
      ________
      Sell vaporizers
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        So like they all suck.. huh. Figures.
        I did like that Drambuie... I'm going to end up throwing a few grand at this aren't I?
        ________
        Jaguar mark v picture
        • crabstick
          • Jul 2008
          • 955
          Here be some sprintcats
          http://www.aeromarinerc.com/index.ph...mart&Itemid=53
          you can get the .40 sized sprint here at OSE - http://www.offshoreelectrics.com/products.php?cat=9
          Another hull which is a terrific handling hull is the Aeromarine Conquest and the slightly bigger Avenger
          Matt.
          www.rcboats.co.nz
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            Cool. The MHZ has a complete drive setup to go with the hull. (I hate guesswork)
            Back to the expensive part... it looks like dual motors?
            ________
            AUTOZAM REVUE
            • justintime2w8
              • 323
              If you are not racing pick a hull that looks cool to you and build it. "bad handling" is a relative term. Any of the longer offshore cats won't turn like the shorter sprint cat. They will be faster though.
              What kv 1515's do you have. Those should make plenty of power though prop size may be an issue.
              If you have everything already, get a hull $250-400 and drives $40-$100 rudder $50 and go run.
              www.radtekpowerboats.com
              • justintime2w8
                • 323
                Mhz is good, they make great hulls and hardware, though they will cost more. Seems to be a bit cheaper to go direct from germany.
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  I was looking at the Avenger Pro, looks like they have a hull/hardware kit too.
                  ________
                  Buy bubblers
                  • crabstick
                    • Jul 2008
                    • 955
                    Choose any two: Fast;Cheap;Reliable.
                    Matt.
                    www.rcboats.co.nz
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      They are the 2200kv's from E-Revo's.
                      What hull/hardware are you thinking? That's exactly what I want to do. Get a hull, put it together and go RUN IT!
                      (I've already spent way toooooo much time on the forum and not enough time outside today!)
                      ________
                      Second-Generation Ford Taurus Specifications
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        I'll take cheap and reliable for a thousand Alex!
                        ________
                        Volcano Vaporizer Reviews
                        • justintime2w8
                          • 323
                          Not to sound too stupid, but seriously, pick any 40-50" hull get a pair of speedmaster drives and rudder and go. I would say 4-5s with those motors would be a decent running boat. I would think 45-55mph is do-able then later get bigger motors if you want to hit 65-70. 10-15min runs are possible but you might sacrifice speed for the extra batteries you would carry. Arrow Shark 53" would not be too bad and looks decent too. I think a few of the aeromarine hulls would be fine. Just pick one you like in that size, they will all run good once you get your setup right.
                          At this stage just pick the boat YOU like, then you can get the guys here to give you tips on how to make it run good. I realize you want to make an educated decision, thats good, and every boat mentioned by everyone so far would work for your purpose.
                          My hulls, right now, are too big or too small for your use so I could not recommend them. We should have a middle size soon....
                          • Brod
                            • 196
                            what about a Promise Hobby falcon cat,nice looking and cheap,fast too.There hardware is top notch also,apart from the motors.
                            http://cgi.ebay.co.uk/41-Falcon-cata...item20a977873a
                            there is a build going on at the moment
                            http://forums.offshoreelectrics.com/...ad.php?t=13819
                            Slow gets boring fast.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              Yep, just trying to make an educated purchase to start with. I also don't want to waste any time or money re-inventing the prop when it's all been done before.
                              Ideally, I'd like to find a pre-painted hull/hardware kit, drop in my electronics and go. Buying drive hardware retail a la carte is a greuling process prone to error and very unappealing to me. I want a complete hardware kit, sized for the hull in mind.
                              I sent off messages to Mhz, Arrow & Aero asking if they have a dual electric motor hardware kit for their hulls... We'll see what they have to say.
                              If I have to spend two grand, I will, but won't be happy about it. If I can keep this under a grand, it's a success. If I can keep it under $500, Yeah-buddy, we have a winnner.
                              As for the MPH, I really have no idea. I've never put the GPS on my boats. They are just for fun. I can say the stock EKOS was the fastest and plenty fast for the area I run in. 40MPH would probably be more than adequate. I can adjust the batteries/prop to help the run time as needed.
                              ________
                              Shoichiro Irimajiri
                              • tiqueman
                                • Jul 2009
                                • 5866
                                If your looking at MHZ and that price range.. then dont rule out HPR. The HPR06 is about 45 inches. http://www.swissmodelpowerboatteam.ch/
                                http://www.swissmodelpowerboatteam.ch/115er.html
