MHZ Racemaster
  • mmyska
    • Jun 2010
    • 10
    #31
    Originally posted by DISAR View Post
    Hi,
    can you please post some photos of the boat layout and transom? what is the distance of propeller from transom and which rudder did you use?
    Yes the 580 will heat up for sure and can be demagnetised easily.
    Hi,
    the distance from the transform is 90 mm (to the end of blade, basically to the end of prop by octura)...
    I'm using Octura X445 now (Leopard 4074 1050kV, 6s) , but I would like to try X447/3 - 3 blade for more stability... I hope the torque of Leopard (will try Leopad 4082 1250 or 1500 kV on 6s) will be good anough... The lenght of rudder is aprox 105mm.
    Regards
    Martin
    • DISAR
      • 1137
      #32
      Many Thanks Martin for the photos, nice job!
      the 4082 1500kv sounds very good on 6s with 445-447/3 maybe 130A and 180A max
      I will test mine with NEU 1515 1.5y, 1527 1y, and turnigy 1400. I 've been working on my other boats, preparing the mean machine and df35" for some races plus this twin sprintcat.
      EDIT: I could not find any 4082, just saw these ones in other thread http://shop.turbofanelectrics.com/pr...&categoryId=33
      http://www.rcfastboats.com/
      • mmyska
        • Jun 2010
        • 10
        #33
        Hi,
        you can find variety of leopard motors on himodel.com (incl. 4082) or Kershaw designs page...
        Regards,
        Martin
        • DISAR
          • 1137
          #34
          excellent, I found them
          • mmyska
            • Jun 2010
            • 10
            #35
            I hope, OSE will sell them early too.
            • mmyska
              • Jun 2010
              • 10
              #36
              Today I have tested RaceMaster with following configuration:
              ESC Turnigy 180A
              Leopard 4082 1250 kV
              Octura X445
              2x3S Turnigy 5800 25C lipo (in series - total 6S).
              Temperatures after cca 7-8 minutes full throttle:
              Motor cca 35°C (with small silicon jacket which covers only cca 1/3 of the motor length), Lipos 40°C, ESC cca 35°C
              It seems to be good configuration for this boat. I will test 1500kV Leopard later on.
              Boat is markedly faster then with Leopard 4074 1050KV. 1050kV will be probably good on 8S.
              Martin
              • Gerwin Brommer
                • Dec 2008
                • 928
                #37
                Dutch Racemaster on its maiden ! :
                • Alfa Spirit
                  • 2183
                  #38
                  DISAR, what is the setup in the MHZ Racemaster?
                  I' ve got a MHZ Dragon Lady on the way, this is the same hull but Fountain powerboat look.
                  Thanks
                  • DISAR
                    • 1137
                    #39
                    I have tested a NEU 1527 1y on 6s and now testing a cheap motor 1340 kv, 6s. the boat needs a min. 445 prop.
                    • Alfa Spirit
                      • 2183
                      #40
                      Hello Disar,
                      I received the MHZ Fountain and the Castle Creations 1717 1580kV motor this week, this hull is really amazing.
                      What do you think about the COG for this hull 30% or more? Lenght is 1 meter and width is 21 cm, same than MHZ Racemaster, thank you
                      Here is the setup, 30000 RPM unload :
                      • papenhove
                        • 4
                        #41
                        Here is another vid of a racemaster. This one is a twin and it's mine .
                        If you want I have also some pictures.
                        Paul
                        (Holland)
                        • DISAR
                          • 1137
                          #42
                          This a very good boat that you have. I saw the photos in your Dutch forum, very good construction and excellent handling. I saw similar arrangement in a larger mono (Titus MHZ) from a German builder Tommi
                          And eventhough I have not finished tuning mine, I am very tempted to remake it twin!!!
                          • papenhove
                            • 4
                            #43
                            Thank you for the compliments.
                            • Alfa Spirit
                              • 2183
                              #44
                              A very nice MHZ Racemaster
                              MHZ Fountain vs Racemaster
                              • j.m.
                                • 847
                                #45
                                The hull bottoms look the same, the fountain just has a taller freeboard.
