Build pics of my Aeromarine Titan 33
  • OshkoshMono
    • Apr 2010
    • 207
    #121
    Got the Neu 1521 installed with new jacket, and 40mm rear mount. Had to do a little epoxying. Also, does my drive dog/ stinger gap look ok?
    • JMSCARD
      • Mar 2010
      • 4174
      #122
      yes sir clearance looks fine.... but what the hey are you doing with a carbon prop with that fancy setup? lol...... :)
      • Chuck E Cheese
        • 2136
        #123
        i agree, carbon a waste on that. a general rule of thumb with no bearing is the gap should = the diameter of the shaft. i use a thrust bearing, look at how mine is set-up, the motor isnt in but you will get the idea.
        http://forums.offshoreelectrics.com/...453#post240453
        see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
        • Chuck E Cheese
          • 2136
          #124
          you might also think of going to a .187 shaft if you have problems with it breaking. looks like you are using a .150, i know that is ok on a 1515 but worried it may be to small for bigger props on a mono... just a thought. if you run it without a liner you should be able to use the same stuffing tube, just requires a shaft and coupler.
          • OshkoshMono
            • Apr 2010
            • 207
            #125
            Ha. Ya the carbon is just to figure out the prop size I need. Now with a lower RPM motor I'm really not sure what prop I'll end up running. That would just figure if I ended up breakin cables now. So a .187 would fit with no liner. Is the prop shaft the same size then? It would have to be I guess or I'd need a different stinger. Any suggestions for a prop on the 1050kv 6s setup? Hope it's not too slow. I suppose 1200 kv would have been better. Lower kv should have lots of torque for jumping out of the water eh, or just snapping cables...?
            • OshkoshMono
              • Apr 2010
              • 207
              #126
              That boat is lookin nice! Those parts sure shine! So where do I get a thrust bearing? That looks like a great idea.
              • OshkoshMono
                • Apr 2010
                • 207
                #127
                Looks like my stuff tube is 1/4 x .014 (6.35mm x .355mm) It says K&S stock # 131. This is my spare tube, i ordered 2 when I first started the build in case I messed the first tube up. Will that work with the .187 flex? Also I only have about 1/4 sticking out the back of the transome going into the stinger. Is that enough sticking out for linerless? I see your rice has quite a bit more tube sticking out.
                • forescott
                  Hopelessly Addicted to RC
                  • 3009
                  #128
                  Is that bushing for the stinger supposed to install from the prop end or the transom end of the stinger? I thought that it slid in from the back. I could be wrong but there is nothing to hold it from sliding out and hitting the prop.
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1743
                    #129
                    Is your motor 5mm shaft or 8mm shaft? If it 8mm I have a thrust bearing for it.
                    Forescott the stinger bushing goes in from the prop side. If it does work it's way out it will hit the drive dog before the prop.
                    • forescott
                      • 3009
                      #130
                      Are you supposed to tap it in gently to seat it? Since its slightly beveled at the end??
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1743
                        #131
                        It's starts off tight. The more you use it it will loosen up a little.
                        • forescott
                          • 3009
                          #132
                          Mine slides in and out like butter. It doesn't seem right.
                          • Rumdog
                            • 6667
                            #133
                            They all do. I don't really care for it either. It really isn't an issue though. I do like how it is a slip fit in the stuffing tube though. I divides up the friction between the stub, bushing, and stuffing tube.
                            • OshkoshMono
                              • Apr 2010
                              • 207
                              #134
                              Darn, its 5mm. Does a thrust bearing help keep out the water that travels up the tube? My boat was taking on a decent amount of water today. Got it out for the first time with the Neu and it works great. I couldn't get the motor temps over 80 deg! The lake is a little cold, but wow what a differance a good motor and longer propshaft made. The 45mm prop works ok, but not great. I'm guessing it was running about 40 mph. Maybe 42 or 44 ish. It cavitated for a second or two then took off. I'm thinking a decent brass prop in the 48 to 50mm range will help. Not sure on 2 blade or 3 in a lower RPM setup like mine. What you guys think? 1050kv on 6s...2 blade or 3? Motor was 75 to 80 deg on the 45mm 2 blade carbon prop.
                              • OshkoshMono
                                • Apr 2010
                                • 207
                                #135
                                Mine too, now anyway after replacing it. The first one I pushed in and polished nice with the drive dog, not having enough gap. Ooops. That one came out hard, but the new loose one seems just fine.
