36" Sprintcat with Twins - what motors have you run?
  • crabstick
    • Jul 2008
    • 954
    Hey Crew,
    Looking for people who have setup a 36inch'ish cat with twins, Just acquired one and planning for a sport twin setup.
    Im trying to decide on motors, Really want outrunners but may go with something else, these are what I am considering so far
    Turnigy Typhoon 600's on 6s each
    Turnigy Typhoon 500's on 5s each (least likely option as have been told these motors will not be enough)
    Fiegao 540 9xl's on 4s each
    Info Im looking for is Amps, heat and speeds.
    Thanks
    Matt.
    www.rcboats.co.nz
  • Rumdog
    • 6453
    I'd go 9xl's on 5 or 6s. With twins youll pull less amps because the motors are helping each other out and taking away some of tha load.
    • crabstick
      • Jul 2008
      • 954
      Yeah this is true, Though being a sport boat I was hoping to run 4s as I have 4s packs and 6s packs, but no 5s, maybe I just go twin 8xls..
      The other thing I need to look at is what left and right rotating props are available.
      I saw a vid of an arrowshark 53" fighter (like i used to own for gas) doing around 50mph on twin 8xls
      Matt.
      www.rcboats.co.nz
        • 9479
        Wow, is it possible that a 41" Falcon could run fast on twin XL motors?
        I would love to have one of those hulls but only have twin SV motors to play with
        • crabstick
          • Jul 2008
          • 954
          here is the video of the fighter doesn't look quite like 50mph but you get the idea, running 4s to each motor, these are a BIG low lift hull, im sure the falcon would perform better than the fighter being a wider, shorter higher lift hull.
          Matt.
          www.rcboats.co.nz
          • Rumdog
            • 6453
            That boat was for sale on ebay
              • 9479
              http://www.youtube.com/watch?v=QrKq6Rdb8Pg
              I found those right after I asked the question, thanks for posting those!
              Looks like I may build a 41" Falcon with twins on a budget..
              • Jesse J
                scale FE enthusiast
                • 7241
                Well, I set up my intruder 38" on twin BJ motor/esc combos ran X442s on 4-6S and got near 60 mph. I ran the Proboat ESCs on 6S each WITH internal BEC and had no issues. Everything was 90 deg or less. did not eagle tree it, but would guestimate 50 amp with 70 amp spikes? Maybe those ESCs can handle a lot more... 45A???
                "Look good doin' it"
                See the fleet
                • crabstick
                  • Jul 2008
                  • 954
                  There you go!
                  i think im going to go with 8 or 9xl's.. 4s on each motor.
                  Now whos got a list of available left and right props?
                  Matt.
                  www.rcboats.co.nz
                    • 9479
                    Looks like I might be building one of these cats with twin SV power, and see what kind of speeds I can get..
