Thanks for your under standing Brian.
4 Prop Conquest build
--Albert Einstein
and this was done at a pro shop
Body shops are used to metal body and thick skin fiberglass. It kind of wyhat I have been fighting for a long time with my thin skinned hulls. it really sucks
On a good note are you going to be in LA this weekend?
Yeah , a statefarm prefered body shop, ha ha.....So I cut my wages a half hour today so I could get there before he closes the door and pick up the hatch today because he said yesterday someone will be there and the place was locked up ! This guy doesn't want to keep his guys working i guess in a slow economy....I should have listened to my nieghbor about that guy......No shop integrityOriginally posted by Brushless55 View Postand this was done at a pro shop
--Albert Einstein
I agree man, a prop shop should know what the heck they are doing... rc or full scale!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Wish i could ! Will be working. I have a boat that I will be delivering to a cousin in santa rosa and i am sure we are going to need a place to run them so maybe we can hook up somwhere around Walnut Creek to give my rico and my cousins sv a maiden..Originally posted by RandyatBBY View PostBody shops are used to metal body and thick skin fiberglass. It kind of wyhat I have been fighting for a long time with my thin skinned hulls. it really sucks
On a good note are you going to be in LA this weekend?"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
What did you use to cut the area where the motor mounts go? Looks very clean for carbon fiber...Originally posted by rearwheelin View PostHands down a $200 mount . If I ever build another twin conquest I would definatly roll with this one
I will resin the edges of the cf later on.
I use a diamond tip dremel cuter, its about the size of a pencil tip, other tools are : wet tile saw with diamond tip blade and belt sander is all i use on the cf. When ever i dry cut I have a shop vac right on my cut somtimes a dust mask too.Originally posted by keithbradley View PostWhat did you use to cut the area where the motor mounts go? Looks very clean for carbon fiber..."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Its black ! I will post more pics after i pull tape and get everything in and on..Might be a couple days..Attached Files"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Ive thought about buying some of the diamond tip cutter but wasnt sure how well they worked. They are on my list. Thanks for the advice.Originally posted by rearwheelin View PostI use a diamond tip dremel cuter, its about the size of a pencil tip, other tools are : wet tile saw with diamond tip blade and belt sander is all i use on the cf. When ever i dry cut I have a shop vac right on my cut somtimes a dust mask too.
They last forever , I am still using my first !Originally posted by keithbradley View PostIve thought about buying some of the diamond tip cutter but wasnt sure how well they worked. They are on my list. Thanks for the advice.
--Albert Einstein
I look forward to your visit. Let me know a five days before (if you can) so I can have the time off.Originally posted by rearwheelin View PostWish i could ! Will be working. I have a boat that I will be delivering to a cousin in santa rosa and i am sure we are going to need a place to run them so maybe we can hook up somwhere around Walnut Creek to give my rico and my cousins sv a maiden..
I had to get ride of my 10's to make room for baby seats...ha ha !Originally posted by TotalPackage View Post4Wheel? you do any car stereo? Nice azz boat by the way!
--Albert Einstein
Got a little work done tonight .... Will try and finish her up tomarro and start on a shipping cage...Seems like 1 day off from work just isn't enouph !
--Albert Einstein
