4 Prop Conquest build
  • Rumdog
    • 6667
    #46
    ALL brushless motors will produce heat quickly with no load. No matter what the timing. Bench testing at high rpm is a very bad idea.
    • rearwheelin
      • 2101
      #47
      Originally posted by bustitup View Post
      leave it to crazyfast to come up with this.........its worth watching his vids just to hear him laugh
      from the first time a saw his sprintcat40 video I had to have it...its the one in my avitar with fake paint job...lol
      way to rock Randy
      Whaz upppp !!....What is my R&D lab doing in your avitar....lol
      --Albert Einstein
      • crabstick
        • Jul 2008
        • 955
        #48
        id try it with the lowest timing setting...
        Matt.
        www.rcboats.co.nz
        • rearwheelin
          • 2101
          #49
          Thank for that info Rumdog .
          The motors seemed to cog worst around half throttle .
          --Albert Einstein
          • rearwheelin
            • 2101
            #50
            Next run out timing will be set at 0, when purchasing the Turnigy esc's I highly recomend the programing card, it didn't even take 5 min. to program 4 esc's in the boat !
            --Albert Einstein
            • rearwheelin
              • 2101
              #51
              In my test run my drives were butted up against octura thrust washers with no measured gap for cable shrinkage, my thought was the that the play in the teflon liner would be enouph for cable shrinkages and the octura thrust washers would minimize the friction between the drive dog and strut. I like to thrust my boats with the strut , I believe this is the way to build a great handling boat. I have heard that that leaving to much of a space sends the thrust point to the motors and is a good way to make your boat plane out flater but this type of thrust is really bad on you cables and stuffing tubes.
              --Albert Einstein
              • Rumdog
                • 6667
                #52
                Leaving no gap is bad for the flex cables. They will shrink up during load. with no gap, you give no room for shrinkage which can lead to snapped cables.
                • crabstick
                  • Jul 2008
                  • 955
                  #53
                  for sure Rumdog, good post.
                  Matt.
                  www.rcboats.co.nz
                  • rearwheelin
                    • 2101
                    #54
                    Thanks RUMDOG , just getting some pre test jitters. Like the good advice on this forum sometimes ask questions that I kind of allready know the answers too but need to be sure . Will be testing friday , should have the local lake to ourselves , am going to try a pass with thrusting point on motors( I may change my mind on this one, seems like it would stress the cable too much) then going to experiment with thrust bearings on struts . Hopping to gain another 5-10 mph Also a few esc timing changes. Then might order some 8xls and soom cooling jackets
                    Will have some more video later with more speed on laps.
                    --Albert Einstein
                    • crabstick
                      • Jul 2008
                      • 955
                      #55
                      I too prefer load on the strut, but i try to run a little cable gap to allow for cable shrinkage, I have broken cables by running them too tight.
                      Matt.
                      www.rcboats.co.nz
                      • rearwheelin
                        • 2101
                        #56
                        Wowzerrzz !!! This boat is fun ! Tested with a gap of about 2 mm and handling was a bit twitchy , still predictable though , but the hull didnt settle on the water very well. ESC timing was at 0 deg.. I got pretty wild with it , new video www.youtube.com/watch?v=HVcBR85vC_Q Next time around I will run new motors and possible thrust differential.
                        This is a video from today of my old Titan 29'' going 52.4 mph The new owner is very happy www.youtube.com/watch?v=iLXUVom1naA....sorry about the comentary..lol
                        --Albert Einstein
                          • 6057
                          #57
                          That is a great place to run boats...........looks weedless, nice clean shoreline.........most likely snake-free............ Did you record your temps after that last vid run?
                          And yes..........................the boat still rocks
                          • blackcat26
                            High Speed Junkie
                            • Sep 2009
                            • 1750
                            #58
                            Cool video I love the 4 rooster tails! Can you change the pwm on the esc? That may help the cogging. I may be the last to realize this buy you are the one with the 75mph mean machine on youtube!!!!!! That thing is crazy!
                            • Norman2
                              • Sep 2008
                              • 354
                              #59
                              Hi Rearwheelin,
                              Just want to say that this is the most creative and well done build that I have seen. Wish I had
                              your talent. Regards
                              Norman2
                              34" Ekos Cat UL-1 Powered
                              • rearwheelin
                                • 2101
                                #60
                                Temps were absolutly great on esc's and lipos, under 100 ! Motors got really hot , one of them was around 240 deg. and also a siezed bearing. They were my cheepo test motors so its o.k., had a lot of fun on the third run The lake I was at is part of Bakersfield newest baseball park complex and was recently filled after being empty for a couple years.
                                --Albert Einstein
