HIPPIE"S VS1 build
  • rchippie
    • Jan 2010
    • 640
    I got my outboard mounted. Thank's to jeff (obrien) for the help. I also got the back plate with all the pass thru's done as well.
    • bigwaveohs
      • 606
      Originally posted by rchippie View Post
      I figured i would start my own build thread . I fixed the gap in my hull . Today i made some sides for my battery & elctronic's box. They are just taped in place because i wanted some opinion's in case im doing something wrong. My plan is to cut out the back of the stock radio box to leave more room for adjusting the lipo . I hade to make my new sides go on top of the stock radio box because my turnigy lipo is taller the the stock box. Tell me what you think .
      Did you cut through the top deck and styrofoam to lower the radio box electronics in the hull?
      I let the dogs out...
      • rchippie
        • Jan 2010
        • 640
        No i built it on top . I built mine pretty much the same as ozzie built his .
        • ozzie-crawl
          • Sep 2008
          • 2943
          look good mate,just one thought were you have the steering rods you dont have much vertical adjustment,if you put the steel cleats on the servo side you can then use the pivot balls on the out side with a bolt to allow leg to move up and down and the rods stay in the same spot,i had a nut either side of pivot ball to allow adjustment but now i have it dialed in, i have a piece of tube one side and a nut they other,will take a pic tomorrow show what i mean
          • rchippie
            • Jan 2010
            • 640
            Scott
            I figured out what you meant about the links. Here is what i made. Plus there is a couple of pics that show the amount of throw.
            Also i all ready sealed the boat . But i need to put severasl coats of clear to protect it . Is it okay to us KRYLON for the clear coat, or is it better to use something else?.
            • rchippie
              • Jan 2010
              • 640
              I got some more work done.
              • rchippie
                • Jan 2010
                • 640
                I would like to take my VS1 out for it's maiden run tommorow. But i do not have any corrosion x to spray in the motor after the run . Is there anything else i could use or should i just wait untill i can get some corrosion x ?.
                • Rumdog
                  • 6667
                  WD-40 will work well too!
                  • bigwaveohs
                    • 606
                    WD-40 is fine...in fact I have rolled and sub'd mine a number of times and just blew any water out when I got home...UL-1 motor still runs fine...
                    • rchippie
                      • Jan 2010
                      • 640
                      Thats great. How much do i spray in the motor ?. Also should i spray denatured alcohol first or it that not needed ?.
                      • Rumdog
                        • 6667
                        Spray it with a little WD-40 before you run and unless you flip, it'll pretty much bead off any spray. If you have compressed air, there isn't really a need for the alcohol but it cant really hrt.
                        • rchippie
                          • Jan 2010
                          • 640
                          How much is a little wd- 40, also do you put the little red tube all the way in the motor can or just spray around the holes on the end bell ?.
                          • Rumdog
                            • 6667
                            Dont worry about over doing it. Give it a good soak if you want. Try to get it on everything you can.
                            • rchippie
                              • Jan 2010
                              • 640
                              First off i must the Ozzy-Crawl ( scott) & Obrien ( Jeff) for all there help. With out them i would still be working on my boat.
                              My VS1 had it's madien voyage today. It was totally AWSOME. The boat was super stable & fast . Even the nitro guys were impressed, with how well it handled. Im using a UL-1 motor on 4s with a 42/55 grimracer prop.
                              • ozzie-crawl
                                • Sep 2008
                                • 2943
                                great news,there a fun boat to drive.
                                i sold mine and the people who brought it just ran it at a state titles (same setup)
                                it had the least powerful motor but still got 3rd overall and a trophy
