thanks for the Comment I have one more sanding and then I am going to polish the whole thing, I will post more pictures
Twin cat p.eells style (cat scratch feaver)
Peter Eells; Fun, and Helping others To Have Fun!!!
RC.Boats.by.Pete@gmail.com
Fit Up For the Hardware
Well here I am again Dinking around waiting for my pictures to up load on photobucket 81% and holding, Dum ta Dum, Well I had to cancel the up load adn do it one picture at a time BUT I Got er done
I just fitted the rudder on and the struts to check and see how everything looks, Now I am going to polish up that new hardware and it will look Sweet.
Very nice work on that rudder and i like those strutss,,what props are those!!!! look bigger than the one on mine!!!
Those are x430 and x430R w/ 1/8" shafts and .098 cable Right Lay and Left lay for counter rotation, And thanks HJPeter Eells; Fun, and Helping others To Have Fun!!!
think i may need to modify my rudder to run alittle deeper,, do you think you could make me a replacment blade for it, with those sweet machining skillzzz you got there!!!! I have a bigger rudder at home i will look at it tonight and see if i cant cut it down alittle to see if i can fit it on my rudder bracket on my hull,,first..
My rudder blade is only 2" long and that seems to work fine for me how long is your's? if it is down in the water it is working, well most of the time unless it is just touching the water, and I guess i could make a rudder blade but I can't do a water pick up type as I use 1/8" aluminum plate for the blade and 1/8" brass rod for the pinPeter Eells; Fun, and Helping others To Have Fun!!!
It is in the water, i think maybe an inch or so in the water,, i may not need it ill have to measure it tonight,, wouldnt need the pickup but ill look at it tonight!!!!Get to buildin!!!
Thanks for the motovation, I have a bunch of finish work to do now coating everything with epoxy prining and making the hatch look just right and stuff like thatPeter Eells; Fun, and Helping others To Have Fun!!!
Ok here are some more pictures of the rudder all polished up, I had it done on Sunday but just now had the time to post sorry.
Well that is all for today but next time I am going to finish the top of the stand off box by sealing it with epoxy (I love that stuff) then glueing the top on, and after that I am going to make another foam shape for the cockpit or what ever you all call it.
Well I finally made more progress I have some phone Pictures, and will Be posting them this weekend (I hope) so at least everyone that has been watching will have something a bit newer to look at. I added 90 deg water hookups to the water jackets, and purchased some (2) bottom mount water pickups from cnc aluminum, Mounted the struts Glued up the (With Bearing Mount) flex shafts, added stuffing tubes and just did a lot of looking, and added a battery strap (modified of course) did some sanding and that's about it. Stand By for Pictures.
New Pictures
Here ar some of the updates I promised.[/ATTACH]Prop shafts Ready to Install.jpgIMG_0768.jpgPeter Eells; Fun, and Helping others To Have Fun!!!
Adjustments
https://oi943.photobucket.com/albums/ad280/peells/LYNX%20VERSION%202/IMG_0770.jpg?t=1579369103Peter Eells; Fun, and Helping others To Have Fun!!!
Tools
These are the tools I use (Well some of them anyway)
