HOTR twin build
Had it back in the water yet?Originally posted by tiqueman View PostTypically its mounted towards the rear of the tunnel (near the transom, bottom side) kinda like a wedge and helps keep the nose down at high spped. Ive seen some do a spoiler type at the top/ front of the tunnel as well, on the deck. Once I get it trimmed back out it will be fine. It was perfect before I scuffed the hull. If I cant get it right, I will just re-spray epoxy paint on the bottom and get it back to where it was.
________
Rohypnol rehab forumsLast edited by FighterCat57; 02-14-2011, 10:22 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Nah Ive been too busy to really do much at all during the light hours of the day.. but Im not complaining one bit.
I was hoping to get it in the water today but it rained all afternoon... but this am when I was doin work it was beautiful.. go figure.
Yeah, rain rolled in as I was ready to take out the new gas cat... That's the great thing about living in FL. The weather is great almost every day almost all year round. Except for hurricanes!Originally posted by tiqueman View PostNah Ive been too busy to really do much at all during the light hours of the day.. but Im not complaining one bit.
________
FxLast edited by FighterCat57; 02-14-2011, 10:22 PM.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
Tell me about it... How long have we been w/ out rain.. and today I try and take the 1:1 boat out... get it all ready to go and the clouds unleash....Originally posted by BenjaminR View PostYeah, rain rolled in as I was ready to take out the new gas cat... That's the great thing about living in FL. The weather is great almost every day almost all year round. Except for hurricanes!
I guess the next couple days are supposed to be crappy.. then its back to that sunshine stuff.
Not one to cloud another mans build thread but I have a bit that might help here.Originally posted by Rumdog View Posttry an airdam in the tunnel to help keep it planted at high speed. It worked excellent on my sprintcat.
I have a dam in my Cat at the moment as Matt (crabstick) told me it might help.
It does. !!
So far I have only had one good run with the dam in and it made the hull a lot more controlable. It would previously blow off with all the same settings.
The dam was placed at the point where the tunnel ramps down and then goes flat.
I have now moved it forward and this will decrease the effect of it. I will play with the dam for a while until I get it right.
Why do I have an air dam at all
After all strut adjustments is is clear that my hull design is not suited to high speeds so I need to reduce the compression lift that the tunnel produces.
I may play with cutting out the tunnel traps at the rear to see how this affects it all. I suspect that this will reduce the lift at the rear and cause blow overs again.
Lots of work to do and lots to learn.
