MRP Fountain - steps and outdrive(s)
  • Make-a-Wake
    FE Rules!
    • 5554
    #61
    The new rudder setup and transom repair went just fine..............just got back from a 2/3 throttle run...........thank goodness thats all i did because i put fresh batts in the TX and i have realized that the servo is the culprit.............it randomly changes its centerpoint, so i have to over compensate for it, then it goes back to the old centerpoint...........overcompensate the other way................what the H......???? Its going in the trash. Thats why i crashed the other day..............freakin zig zaggin all over I didnt have my temp gun after i got it in, but i could hold my finger on the wire end of the endbell for 5 seconds..............that should be good i imagine.
    • Make-a-Wake
      FE Rules!
      • 5554
      #62
      Still does it............so.........i took out the red pin from the ESC, threw in a 6v Rx pack and it worked fine..........?? I have heard that 2.4ghz radios dont like sudden voltage drops...............could be true. Ran very nicely..........now that everything is "ready" i can vid on Sunday.
      • justintime2w8
        • 260
        #63
        Built in bec might have an issue.
        Carl when are you running this weekend?
        www.radtekpowerboats.com
        • Make-a-Wake
          FE Rules!
          • 5554
          #64
          Most likely on sunday afternoon...........I'll be there from around 2-7........gonna fish too, caught some good ones last sunday! We need to see about making some adapters for your esc to my batts.
          • justintime2w8
            • 260
            #65
            Ok, you will have to call me again it did not ever ring my phone.
            Did you decide what will work for you on the novak, I have two female deans on my desk. I also have 5.5 bullets.
            When do you want to actually run boats, I am free all day. I ran a few times this week, I really feel like I have the 24" dialed in now, you will be impressed. What do you have in 3s 2000-3000mah with a decent C rating that we could try? I am going to order a few at some point but my budget keeps getting shot to heck.
            • Make-a-Wake
              FE Rules!
              • 5554
              #66
              My stinkin' servo is still turning right at full speed.............it justs re-centers itself off to the right. In order to get it back in i have to give i nearly full left steering, then i pick it up out of the water and its straight again......... I am still running the receiver pack, whats up?
              It's running awesome when it runs straight for the first two minutes or so......then the servo deal kicks in.
              Any thoughts here?
              • Jesse J
                scale FE enthusiast
                • 7241
                #67
                1) no CF I assume?
                2) 2.4 ghz you said? I had issues with my FM in a boat, added external BEC and no more problem
                3) wet receiver? try another one if you have one
                4) did you try a new servo? they get unreliable when the get wet
                "Look good doin' it"
                See the fleet
                • Make-a-Wake
                  FE Rules!
                  • 5554
                  #68
                  Yep, 2.4, 6v power supply for RX, second servo I've tried, does it with the bec supply too. Are you going to run the 6s or stay at 5?
