flat pc of plywood 3/4 in or thicker Small wood plane(mini plane) Hobby knife and blades Sanding blocks 80-150-220 grit paper Drill and bits CA glue and accelerator Epoxy resin Lots of clamps, bar clamps spring clamps, paper clamps C clamps Bricks to hold things down,like the deck Razor saw Wide tape Wood filler Primer and paint I like to use Titebond 2 for glue, then coat with resin Larry
Tools and supplies to build a wood boat
Thanks for telling us this,,,but why???Grand River Marine Modellers
And Pins, lots of Pins. I use pins and masking tape when building with balsa or foam and clamps when building with ply.Paul Upton-Taylor, Greased Weasel Racing.
I use the Titebond, then epoxy. CA makes me sickOriginally posted by mrrc View PostFrom a first time builder THANKS!
Using balsa do you guys initially glue with CA and then epoxy and wood glue , or is the wood glue only for plywood , Basicaly Im asking when do you use what glue?Last edited by blizard05; 02-28-2010, 08:17 PM.America home of the free, thanks to the brave [/url]
