Vortex 22" on 2s or 3s
  • sampit
    • Jul 2009
    • 466
    Ok cheers,
    would this work Ammo 36-50-2300kV 4s2p
    what size strut and rudder should i buy
    do i need an ofset rudder?
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    • Jeepers
      • May 2007
      • 2050
      4s2p is not needed.
      • sampit
        • Jul 2009
        • 466
        Guys,
        Do you think this set up is better than placing the bateries in the sponsons
        i am not really sure what to do for the best,
        setup so far
        etti 150A esc with extra power caps if needed
        4s 2p 5400 mah
        also anyone help with motors looking for around 50 mph
        short list
        neu 1515 1y
        Fieago 7XL, 2370KV
        Ammo 36-50-2300kV
        Ammo36-56-2030
        Ammo 36-56-2600kV
        cheers
        sampit
        • ace028
          • 986
          Looks like it would work fine that way, look at this guys setup, he is using a123 batteries but it should give you a good idea as to placement.
          Twin power =
          • Rumdog
            • 6667
            As long as the cog is correct, it doesn't matter if theyre in the sponsons or not.
            • sampit
              • Jul 2009
              • 466
              Great , this way all my wires will connect without to much trouble
              and allow for a bit of adjustment from the packs
              • sampit
                • Jul 2009
                • 466
                is there any particular hardware set available at the moment for 21" hydro's, I read that there is a different to mono's and need to be offset, no one seems to have one in stock, any pointers appreciated
                I would have liked a solinger set but cant find one for sale new or old
                • wakeboardfusion
                  • 514
                  I am planing on running mine this weekend on 2 2s 5000 batts. I hope to have video!
                  • Steven Vaccaro
                    Administrator
                    • 8932
                    You can run the ul-1 strut and a speedmaster mini rudder.
                    http://www.offshoreelectrics.com/pro...od=dh-aqub6950
                    http://www.offshoreelectrics.com/pro...d=ros-mini-rud
                    Steven Vaccaro
                    • sampit
                      • Jul 2009
                      • 466
                      If only I could find a suitable 3/16 strut and rudder set to buy new or old,
                      this seems to be my biggest challenge up to now, just cant find one
                      was even thinking about using a UL-1 strut and rudder
                      good luck for the weekend looking forward to the vid
                      what motor you running?
                      sam
                      • sampit
                        • Jul 2009
                        • 466
                        Thanks Steven
                        we must have been writhing at the same time
                        so the ul-1 strut will work great news
