ECO Build - "Rush"EVO (clone of Sonic EVO)
  • CornelP
    • 793
    Well, I finally got the hull and started working on it.
    Got it from:
    Quite a good quality hull for the price, the floodchamber comes as a kit comprising wall and FG tape. I doubt it is gel coated, as it cleans waaay to easy with sand paper...
    I installed the floodchamber and realized the left side is a bit wobbly, very difficult to tape it. One 2mm piece of balsa, laminated with light FG on both sides later, it is nice and stiff.
    I also marked the future holes for the hardware, whenever this will arrive...
  • bonewar
    • 587
    CornelP,
    Looks like a space ship out the movie INDEPENDENCE DAY !!!!!
    Like to see how she preforms ????
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • Gerwin Brommer
      • Dec 2008
      • 928
      Cornel :
      That's the German way of gelcoating a hull.
      Only a very thin layer of coat.
      • CornelP
        • 793
        Ok, so I need to be careful with it or just repaint...
        • ralex
          • Feb 2010
          • 1
          and what hardware do you want to install ?
          • CornelP
            • 793
            Will post it once I get it...
            Depending on the class, it will get a brushed Team Orion 14T or a Feigao 11S on 7 cells. Lipo is not yet officially accepted here...
            Running hardware is home made, 1.5mm wiredrive on a ball bearing strut, stainless or carbon rudder.
            • j.m.
              • 847
              I'd say stainless on the rudder, it'll be hard to keep it thin and sharp with carbon.
              Pretty boat!! Yes, the hull is gellcoated but being a race hull, all excess weight was removed. Including excess epoxy from the layup and surface coat. This might not be necessary if you guys ran LiPos.....
              Jon
              • CornelP
                • 793
                Well, I will run NiMh only if I will go to the official competitions... our unofficial races are sort of "open"...
                • CornelP
                  • 793
                  Well, here are the first runs... on Lipo, as the brushed motor could not get to the correct rpms on my pack (Team Orion 6 cell 5300), probably not correctly formatted, but I'll get them through a few cycles for next week. First run is a 29mm prop, second is a 32mm, both Graupner brass. I am waiting for an order for some H&M stainless props, so we will see.
                  • CornelP
                    • 793
                    These are the pictures as of today... still needs a coat of clear and a silver on the bottom.
                    The small servo is a HD micro 2216MG, with plenty of torque and very fast. ESC is a LRP car capable of 70A, with reverse (not used). This will be changed, as I do not really fancy the soft start.
                    Motor support, coupler, 2mm wiredrive and rudder (stainless) are all home made, so far performing perfectly.
                    • bonewar
                      • 587
                      Nice work there CornelP,
                      Theres not much room in there .
                      I really like your paint work. looks awesome.
                      If you where to paint a thin black line around your paint work
                      it would really make it stand out. POP !!
                      Good job mate.
                      Bonewar
                      • CornelP
                        • 793
                        I will try, but my hand is not so steady... I could not go for a more complex scheme, as this will be racing, so I have to watch the weight. I am already at 1,1kg, about 100g too much, so need to check my runtimes.
                        Initially I wanted to line it with CFK or simple carbon, but that would have added too much...
