traxxas villan build
  • j.m.
    • 838
    #121
    I think that's going to be about 2 times more expensive on the electronics.
    9xl, 120A Aquastar, shipping from hobbycity= $117
    9xl, ICE 100, PiStix, shipping from OSE=$200
    The ICE 100 won't handle as much current, isn't watercooled, and will need a PiStix.
    You can save on shipping from china by ordering your batts at the same time, but the prices from hobbycity still end up being cheaper with the expensive shipping.
    Jon
    • 20psinow
      • Feb 2010
      • 146
      #122
      i know its still cheaper then ose but i have had a fue problems with hobbycity and my cash card!! they dont seam to want my money!! so if i have to spend more money for stuff that i want well thats the rout that i will go.. dose ose have any esc that can handle the current with out spending 200 on the esc alone?
      • j.m.
        • 838
        #123
        huh... Do you have a paypal?
        Over the Turnigy Aquastar, I'd go with the Etti 150. A tried and true contender.
        • 20psinow
          • Feb 2010
          • 146
          #124
          no i do not have a paypay!! i think thats why is did not go through the 2 times i have tried to order..
          • 20psinow
            • Feb 2010
            • 146
            #125
            so the Etti 150 and a 9xl and still able to use the batterys i have now in 14.4v's what kind of speed will i be looking at? and will that prop that i have still be to big for this setup?
            • j.m.
              • 838
              #126
              What exactly are your batteries again?
              • Eodman
                • 1253
                #127
                I'm running a Mean Machine with a Fiegao 9xl and an Etti 150 & it runs well and just warm to the touch after 4 or 5 minutes! Lipos 2s 2p
                Oh I did add the lager Cap Bank that Etti sells - still under $200.00
                If I remember right I've got an x442 on it!
                We did it with a Bang!
                Cats Are Where It's At!
                • j.m.
                  • 838
                  #128
                  What prop on that mean machine?? A 9xl on 2s?
                  • Eodman
                    • 1253
                    #129
                    2s 2p -- 2 2s in series
                    • j.m.
                      • 838
                      #130
                      2-2s packs in series is 4s.
                      2s 2p is two 2s packs in parallel.
                      • Eodman
                        • 1253
                        #131
                        Oh what the hell -- I guess at my age I need to eat some brain food! Can't keep this lipo nomenclature right ... just take me out back and shoot me!
                        • 20psinow
                          • Feb 2010
                          • 146
                          #132
                          well i went to the paint supplie store and got the right resin (epoxy resin) not the poly resin that i have.. and some mixing cups and sticks.... so now im going to get the glass done this weekend.. and my batterys are radioshack 7.2v 2000mAh Ni-Cd (turbo racing battery pack) thats 8years old!
                          • 20psinow
                            • Feb 2010
                            • 146
                            #133
                            well started on the outside of the transom, sanding it down and rubed a hole through the deck area so filled that in and got to let the epoxy cure and sand it down and this should be done till paint
                            • j.m.
                              • 838
                              #134
                              I wouldn't trust those batteries to more than 20 amps constant.
                              Which ain't gonna happen on your hull.
                              Even if you did have a reasonable setup, 2000Mah would last about 2 minutes.
                              That hull is shiny!! Your definitely going to have one of the cleanest Villains out there.
                              Jon
                              • bwells
                                • Jan 2009
                                • 842
                                #135
                                In the last post, pic 2 shows a "gutter type" seam which goes all the around the boat where the deck and hull are joined. I have another boat with a more pronounced "gutter" that I was wondering if this could cause lift, sort of a compression hull? Maybe just over analyzing or hoping!
