JAE Builds
  • egneg
    • 4759
    #286
    Originally posted by pmx View Post
    Anyone securing the lid with something other than tape?
    Thinking about trying adding a gasket to the lid (on the stock lid, not the fighter jet lid), then using two bolts/wingnuts to clamp it down.
    Spending too much time taping!
    To get a good seal you will need a bolt every few inches. I did this on a Campbell hydro and it is worse than taping imo.
    IMPBA 20481S D-12
    • Eric Bourlet
      • Jan 2010
      • 104
      #287
      ZI used to use a screw down lid on an old nitro boat screws every 1/2" and greese. or vasaline. To get a waterproof seal thank goodness for tape!
      Eric Bourlet
      Team Airtronics
      Team M&D Designs
      • Chilli
        • 3204
        #288
        Originally posted by egneg View Post
        To get the AQ motor to fit I have put the cooling in/out on the bottom of the motor. Do you folks see a big problem with this?
        Chuck, I try to keep the fittings as close to the top as possible to keep the air bubble as small. For some reason the Aquacraft cooler fittings are allot closer than the Neus and Castles. This was almost a problem with the narrow cowl on my Insane Sport Hydro. With the Castle motor The fittings were spread out much further. I had the exit fitting staight up and the intake fitting down low to the side. When I switched over to spec power with the UL1 cooler positioned the same way, the intake fitting was rubbing against the cowl. I was able to twist to can to get a decent compromise. Similar to the JAE pic attached.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • carlcisneros
          • Jan 2010
          • 1237
          #289
          I remember that!!!!!!
          My Water Spider had that type of lid and it was all I could do to keep it Greased up all day at the race.
          Thank goodness for tape indeed.....................
          • egneg
            • 4759
            #290
            Mike, I had to compromise ... my cooling can is very similar. I have to keep both fittings to the side to clear the hatch. I think this will work much better than having both fittings on the bottom of the motor. My tub is a bit wider than than the stock JAE tub so I think I am good to go.
            IMPBA 20481S D-12
            • Doug Smock
              • 5359
              #291
              Chuck run that motor within it's limits and it will be fine no matter where the fittings are.
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • Chilli
                • 3204
                #292
                So how did your weekend go Mr Smock?
                Mike Chirillo
                • Doug Smock
                  • 5359
                  #293
                  Hey Mike,
                  I worked my butt off lol, and had a blast doing it. Another Spring Nats in the books.
                  Raced 60 scale and brought home a first place with a boat borrowed from Rick Bellinger our Dist. Scale Dir. Man what a hoot!!!!
                  Picked up a 1/8 scale from a good friend this weekend ( Thanks Kevin!!). I'll be working with Rick to get some FE 1/8th scales running with the 60s in D13.
                  Our good friend Buddy Lowe took home enough wood to build a house! LOL
                  D.
                  Ran some FE's this morning while everyone was getting set up. Lots of interest in the P Limited Hydro and O/B Tunnel.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • Chilli
                    • 3204
                    #294
                    Glad things worked out for you. Congrats!!!
                    Mr. Lowe is the man. We were sorry to see him move down south.
                    Mike Chirillo
                    • Doug Smock
                      • 5359
                      #295
                      He's a great guy, we had a bunch of fun. Most of it was at Julian's expense.
                      Had some fun with Tracy too, another great guy. He had his share of issues this weekend but still took home some wood.
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • pmx
                        • Nov 2010
                        • 63
                        #296
                        I'm really happy with my JAE21 and wouldn't trade it for one of these, but it looked interesting (and chea
                        ose edit :dead r2hobbies link removed
                        31.6" RC EP Wooden Sea Arrow ARR Racing Outrigger Boat
                        Model Number : rcbt0401004
                        R2hobbies proudly brings you a Adjustable Sponsons Outrigger!
                        We studied most Outrigges have Fixed Sponson and make it hard to turn. This Wooden Sea Arrow is now here to bring you new experience to adjust Sponsons.
                        Sea Arrow's Body and Sponsons are Fine Cut and shaved with smooth shinny outfit. Slick Edges and Angles are carefully processed to foster edgeless body.
                        Distance between 2 Sponsons is easy to adjust. They joined with Ultra-Strong Carbon Fiber Tube and metal clumps, which make it much easier in turning or attain its Optimal High Speed.
                        This kit includes Rudder, Shaft Holder, Flex Shaft, Wooden Mount and Water Tube. Install all the Electronic Devices and Run this Speedy Boat!
                        Features:
                        Adjustable Sponsons Distance
                        Made of Strong Polished wood
                        All Wooden part are coated
                        Large Cabin for Heat Exhaust
                        Pops' fleet: Challenger 43, SuperVee 27, Pro Boat Fastech
                        Mine: JAE 21-FE
                        • Doug Smock
                          • 5359
                          #297
                          Another FE for a IC guy.
                          This ones going to a IC guy in Vegas.
                          Good luck with her Jim!!
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • egneg
                            • 4759
                            #298
                            Looks great Doug ... I think you have this boat down!
                            IMPBA 20481S D-12
                            • martin
                              • 2881
                              #299
                              Hi Doug, I have a Mini Sprint on the way to me in the UK. Can i ask you what various glues you find works best during the build process, ie ply to foam sponsons, stuffing tube to hull bottom, general wood bonding. Do you use any CA at all & do you mix any fibres or micro balloons with epoxy at all. Cant wait to get this little thing built & see what it can do. Im also looking at getting the JAE 21 FE but putting something like a Leopard 3674/2650kv just for fun running or maybe a higher kv still for saw type runs to see what the boat is capable of. The JAE boats look like they run very well indeed. Regards Martin.
                              • Doug Smock
                                • 5359
                                #300
                                Thanks Chuck!
                                Hi Martin,
                                I use Z Poxy 30 min for building and Finishing resin for sealing.
                                Good stuff!!
                                Micro balloons go in the epoxy around the stuffing tube.
                                The only place use CA is the bulkheads at the beginning of the build, to tack a triangle block under the stuffing tube inside the hull, and to assemble the ski. I use Mercury High Performance CA. The stuff is awesome!
                                Serious Glue for Serious Projects. Don't trust your project to just any CA. Mercury provides only the highest quality adhesives backed by an unconditional, unlimited replacement guarantee.
                                Good luck with your builds!!
                                Doug
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
