Skunkworks single drive cat
  • Csaari77
    • 26
    Starting on my first boat build and I have a few questions before I start getting everything setup.
    I need to get some ideas on the CG for the boat. Where do I take measurements from? When I'm mounting the motor, do I figure my CG from the back, the middle, or the mount?
    I'll get some pictures up later tonight. Thanks for the help.
  • wakeboardfusion
    • 514
    I think CG is measured from the rear of the two pontoons end and not the absolute rear of the boat. I dont believe they are called pontoons, but i cant think of the correct term off the top of my head.
    • HYDROJERRY
      • Jan 2010
      • 2709
      I think called sponsons, at least thats what they call the ones on an out rigger....
      • Diegoboy
        • Mar 2007
        • 7444
        Sponson:
        the pontoon-like portion of the hull that provides hydrodynamic lift; in the three-point configuration common to current unlimited racing craft one sponson is forward on each side of the main hull
        • bea5017
          • Aug 2009
          • 173
          update?
          • HYDROJERRY
            • Jan 2010
            • 2709
            Yes how about an update, i have the same hull and would like to see how yours goes and what you use in it....
            • bea5017
              • Aug 2009
              • 173
              same, what u throwin in there jerry
              • HYDROJERRY
                • Jan 2010
                • 2709
                not sure yet being i dont no what motor,esc,pro to use, but a guy here is selling a 9xl think i might get it but need to ask around about what to use first,,how about you,,
