Originally posted by j.m.
View Post
new skunkworks cat: twin outrunner build
I used .150 and drilled about 3/8 deep into the tail end of the stinger. Then made a bushing using 7/32 and 1/4" brass. The 1/4 inch is cut the same depth as the drilled stinger. 7/32 is as long as the 3/16 shaft. Works great.
got a little bit of work done, came out decent for first time layin up cf.
A 540 xl is gonna pull alot more than 25 amps and can put out alot more than 1100watts and is gonna pull more like 1900 watts on a x440Originally posted by bea5017 View Post1100 watts is approx equivilent to an 540 xl motor which will easilly push a 32 cat
not saying it wont work though.
read the post. i didnt even go with xls.. and i wasnt talking about the xls pulling 25 amps was refering to a small outrunner motor. fyi my 8xl pulls approx 80 amps * 14.8 volts = 1184 watts...... i know they can produce more power jus depends on the wind and cell count
ordered my rudder and stingers today, who knows how long they will take to get here from china... http://cgi.ebay.com/Aluminum-rudder-...item45f2432b55 http://cgi.ebay.com/aluminum-adjusta...item439b5dda29
I really hope to hear good reviews on that rudder. I started w/ almost the exact rudder on my twin Hotr. It didnt like it at all. It was very loose and very "fish taily" out of the corner, when it would go thru a complete corner. Mostly it would just spin out. I ended up w/ the one Steven sells, http://www.offshoreelectrics.com/pro...prod=ose-80085 , only using the mount and rudder and wow what a difference it made. I also think it helped a lot becasue its a bit further back.Originally posted by bea5017 View Postordered my rudder and stingers today, who knows how long they will take to get here from china... http://cgi.ebay.com/Aluminum-rudder-...item45f2432b55 http://cgi.ebay.com/aluminum-adjusta...item439b5dda29
servo layout. i want to to a pull pull setup with steel cable. anyone no and good servo arms that would work.Attached Files
