BBY War Zone Jr
  • wakeboardfusion
    • 514
    #31
    yes measured it today 75 mm
    • RandyatBBY
      • 3944
      #32
      Gee I run a 45MM runner on mine, you may want to cut it down a little to be a little faster. I like a about 1/2 an inch below the lowest point of the prop .
      Randy
      BBY Racing
      • boater76
        • 574
        #33
        Hey Randy what motor are you running. And are you running any trim tabs and turn fins?
        • RandyatBBY
          • 3944
          #34
          If I was going to run a class with this hull, it would be N1. I would run a 4600kv mamba max motor on 2S1P and a 632prop.
          Randy
          BBY Racing
          • wakeboardfusion
            • 514
            #35
            Would you run the mamba max for the extra weight?
            • RandyatBBY
              • 3944
              #36
              You could run a micro setup, but I am hot on the new N1 stuff
              Randy
              BBY Racing
              • boater76
                • 574
                #37
                Got my hull today Randy. Looks great!
                • RandyatBBY
                  • 3944
                  #38
                  enjoy!
                  Randy
                  BBY Racing
                  • wakeboardfusion
                    • 514
                    #39
                    hey boater, when are you going to start on it?
                    • boater76
                      • 574
                      #40
                      Well as soon as my stuff comes from R2 Hobbies, and Hobby King. I also have to get a custom prop shaft made by Wohlt
                      Ken
                      • wakeboardfusion
                        • 514
                        #41
                        have a video of running today. It needs work!!
                        • Chuck E Cheese
                          • 2136
                          #42
                          from what i remember about bby mini's (the patriot and war zone) the key was to get it ballanced so that it hops flat. i have had several and they all hop, you just need to get it controled. my gecko is the same way, hop, hop, hop but it is controlable when you get them ballanced right. try it with the cog, not strut angle..
                          see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
                          • wakeboardfusion
                            • 514
                            #43
                            yeah the cog seems off, all the weight is at the back. I figure if i add some foam up front and move the batt forward, or add 2 batts 2s2p it will give it enough weight.
                            • boater76
                              • 574
                              #44
                              Are you running a pair of 2s packs? I was planning to run a pair of 2s in mine. I got some parts in the mail yesterday including my stinger strut. I am sending my stinger to Jeff Wohlt for a custom shaft.
                              Ken
                              • wakeboardfusion
                                • 514
                                #45
                                I just used 1 2s pack. Even when put all the way in the bow its still not enough weight to make the cg right. I think i need a bigger battery
