Syncron setup advice
  • BHChieftain
    Fast Electric Addict
    • 2051
    Hi,
    I'm planning on building out a syncron hull, looking for advice on the setup.
    Purpose: Recreational boating (not racing... yet...). Priority is runtime over speed, although I'd like to get into the 40's with at least 7min runtime if that's possible.
    Hardware: standard with the hull
    Batteries: Lipos
    Looking for advice on:
    -Motor? I'm assuming the 540 8XL or 9XL would fit well-- not sure what speed/runtime difference to expect between these motors. Or is there a different motor I should consider? Any particular cooling jacket jump out as being a nifty solution vs. the rest?
    -ESC?
    -Lipo setup?
    -Prop? (I have an extra X440/3, how would that work out?)
    -Servo? (planning to use Spektrum DX3S radio)
    -Anything else I need that I might be missing? This will be my first build (experience up to this point is tinkering with my fastech...).
    Thanks,
    -Chief
  • Jimmy Sterling
    • Apr 2008
    • 417
    Hi Chief,
    You wont be dissapointed with the Syncron, its a fantastic hull.
    As for the setup, assuming you want to run 4s the 9Xl would make for a very nice setup.
    It would be possible to also run a Hydra 120, however this may be pushing it depending on final setup. If price is not too much of a worry I would definately go with a 150 + amp controller (Hydra 240)
    Although I would not recommend starting of with it initially, your x440/3 will be suitable for this setup. Should start off with something in the 42 mm range for initial runs.
    These lipos are definately worth taking a look @, these are the new Thunder Power 45c cells http://fastelectrics.com/batteriestp.asp
    Andrew is also doing a great price on his older TP 30c cells which is what I'm running in all my boats at the moment.
    Any high torque servo such as a Hitec HS645Mg will do the job
    Do you have the hull yet ? any pics ?
    Jimmy
    Come to the FASST side
    • BHChieftain
      • 2051
      I'm assuming the tradeoff between 8XL and 9XL is speed vs. runtime- is that right? Any ballpark on what that tradeoff is assuming a 4S setup? (ie, 9XL ~5mph slower, but 5min more runtime, or something like that?)
      I have not ordered the hull yet, so no pics. I'll update when I do.
      -Chief
      • Jimmy Sterling
        • Apr 2008
        • 417
        I am going to go ahead and say no, there really are too many other variables involved. I only recommended the 9Xl as I have run that motor in numerous boats before and it always seems to work well for me.
        Jimmy
