ClassicHydro Proto Kit-30" Finlay Shovel
  • DCam
    junior member
    • Dec 2008
    • 31
    I'm test building some laser cuts for a new 30" Kit-basically a 12th scale version of the Miss K kit Offshore sells. This will be for Aquacraft LSH etc. I will more than likely include a cowl, dummy engine fins etc with it. First pics show the cuts on the sheets and the laser cut jig that will be included assembled.
    This hull has the tunnel rise starting at the back of the sponsons for less blowover issues. It's Garry's concept for a 27" Karelson shovel which I enlarged to 30.
  • DCam
    junior member
    • Dec 2008
    • 31
    Tunnel and Stringers
    The tunnel has 3 pieces tack glued on the building jig over wax paper. Then the Front Stringers are glued on. So far so good.
    • sailr
      • 7128
      Cool! Can't wait to see this one progress! Great size for LSH!
      Mini Cat Racing USA
      www.minicatracingusa.com
      • DCam
        junior member
        • Dec 2008
        • 31
        Bulkheads
        Thanks! Now the Bulkheads go on. CA glued lined up with the marks on the tunnel pieces. The centers can be cut out after the hulll is built. The last pic is the 27" test build showing the top and Garry's tunnel concept.
        • JimClark
          • 5913
          Looks great Doug
          Billy Graham
          • Steven Vaccaro
            Administrator
            • 8932
            Cant wait to get ahold of this kit! This size will be a real winner.
            Steven Vaccaro
            • DCam
              junior member
              • Dec 2008
              • 31
              Thanks! More to come later.
              • DCam
                junior member
                • Dec 2008
                • 31
                Shears and Deck Stringers
                Here are the pieces added. Took about 15 minutes, Parts are fittting good.
                • DCam
                  junior member
                  • Dec 2008
                  • 31
                  Bevelling for Skins
                  To efectively bevel for fit, I removed the hull from the jig, bevelled the sponson bottoms. Added the sponson bottoms. Then I bevelled the sponson sides and non-trip area. The hull still remained true when I fit it back on the jig. Good deal.
                  • sailr
                    • 7128
                    What kind of glue are you using? I can't get CA to glue plywood worth a hoot. Gorilla glue is a mess, and titebond, etc. takes too long to dry. Epoxy ends up being hard to sand and it gums up the sandpaper.
                    Mini Cat Racing USA
                    • DCam
                      junior member
                      • Dec 2008
                      • 31
                      On ply and most stuff, I find I have to spray the CA with accelerator to make it bond. On some of the skins, I hold the piece in place by hand, apply some thin CA in some critical areas to hold the part, then spray accelerator on it. I finish up the joints with thin or gap filling CA, depending on the fit, let the CA seep in, then spray again. This is one method of course. I always coat the inside when all done with a sealer like epoxy.
                      • Hydromaniac
                        • 955
                        Something else you can do to increase the bond of CA to plywood is to sand the ply at the joint areas with 120 grit sand paper .
                        www.rockymountainthunderboats.org
                        • sailr
                          • 7128
                          Mercury adhesives makes a CA specifically for plywood. Something about the Ph in the wood won't allow regular CA to work. I know Atlanta Hobby carries the stuff. Don't know much else. I have used it and it works as advertised.
                          Mini Cat Racing USA
                          • DCam
                            junior member
                            • Dec 2008
                            • 31
                            Added sponson sides, non-trips
                            More wood added. Still fitting well. The hull came off the jig for the non-trips and sponson sides. Block sanded. Remained stright-good news. Back on the jig now for removal of the bulkhead insides and adding inner side pieces. Then some penetrating epoxy for sealing.
                            • DCam
                              junior member
                              • Dec 2008
                              • 31
                              KIt to be released soon
                              Update on kit! Dubbed the "Miss K+"
                              Changed to conventional type tunnel, still the same size. 30". Steven should be releasing the kit soon. Kit has a cowl, driver, gauges, steering wheel, windshield, and Merlin engine kit. 3 tailfin choices make several hulls.
