Help with a flood chamber
  • BHChieftain
    Fast Electric Addict
    • 2051
    Hi,
    I'm thinking about embarking on a scratch build with an H&M nostep 2 hull. Does anyone have a good procedure for installing a flood chamber? I'm not too sure how to do this.
    Thanks,
    -Chief
  • CornelP
    • 793
    This is the best tutorial I've seen...
    • BHChieftain
      • 2051
      http://www.rcgroups.com/forums/showt...t=floodchamber
      This is very good, thanks. Anyone have tips on how to make the actual template? Measuring inside the hull seems out of the question... I recall reading somewhere about using a long piece of solder to determine the contour, but I'm not exactly sure how to pull that off...
      -Chief
      • CornelP
        • 793
        Long piece of solder or soft copper wire on the outside will give you a rough template... then it's scissor time to adjust. Take your time, a perfect fit saves you a lot of epoxy... :D
        • BHChieftain
          • 2051
          Ahhh, determine the contour from the *outside*.... why didn't I thik of that?
          -Chief
