On proboats site. In this case I had no choice. I t was either cut the back of the stern off or make the bracket. This was less work. Had I cut that seem out the transom would have been about a ridged as a garbage bag...lol
High Speed Rescue Boat
Off to Test
Well I'll call this one complete. I had planed to use carbon rods for a catch. But since this boats only holding me over for a couple months I didn't want to waist the money. So I busted out some wire coat hangers and went to work. Very simple to work with and when braced pretty strong. I even used a peice to brace the steering linkage.lol handy stuff. Im off to the lake shortly to test this thing out. I'll have a clip later on this afternoon.
Is that enough padding? even though this is to rescue boats that are upside down or stalled. you dont want boats such as the jolly to be scratched. At the time of resue you wouldnt mind a scratch to get it safely to shore. maybe its just the pics. I kinda question the strength of hanger wire as well. upside down 36" cat can have quite a bit of drag. Grand Idea with the outboard! awesome
good thing im typing and not talking so i can take this foot outta my mouth. This is just a couple month setup. Get r done! sorry for questioning.
Did u build a pump to fill ur rescue boat with water and then and then pump it outOriginally posted by D.Smock View PostThat's where my head was when I built this. She's three years old now and still saving our butts.
Now she won't set any SAWs records, but she is faster than your avarage Tennesee redneck in a plastic Gamefisher with a 35lb thrust trolling motor.:D
That was one of the most exciting races I have ever been in.
Doug
Failure is the First step to SUCCESS
ya im going to have to go with Mich on this one
Hey didnt u say u have some carbonfiber thing ???Failure is the First step to SUCCESS
Originally posted by Ocean Racer View PostDid u build a pump to fill ur rescue boat with water and then and then pump it out
No sir, the net is capable of lowering 60 degrees. It is operated by a 12vdc actuator.
DougLast edited by Doug Smock; 09-08-2007, 09:21 PM.MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
what do u use to propell it a water jet or prop
and what is that solar pannel looking thing on the roof the circle with lights???Last edited by Ocean Racer; 09-08-2007, 10:20 PM.Failure is the First step to SUCCESS
Can't wait to see the results on this one! Sounds like a fun build! Hope the hull works out for you because your other hull has a slight scratch and a ding on it! lol! I've wanted to do the same thing a number of times. Good call on smashing the s--- out of that one, i feel your frustration.
Hope the build goes well!Where just a bunch A-hulls with boats...
Twin screws driven by Bosch drill motors. Two Proboat ESCs controlled by a stick radio. She drives like a Bobcat. (no rudders)Originally posted by Ocean Racer View Postwhat do u use to propell it a water jet or prop
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
