High Speed Rescue Boat
  • SJFE
    • 4735
    Pictures
    I have the first coat of primer drying now. I will only need 2 solid coats to cover it all up. I finished the sanding with 220 grit. I am headed out to fab a new hatch now. As you can see I have 2 coils around the motor. A jacket was out of the question. The cans vented every where.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      Tom, Dood over at BBY will sell just the hatch for $9.
      It'll be all white & look like this...
      Do you want me to get you one?
      • SJFE
        • 4735
        LOL just emailed Randy 5 minutes ago....funny stuff :P. Thanks man.
        • SJFE
          • 4735
          Well shes primed. A coat of white will go on in the morning and the day glow orange will be applied in the evening. I'll sure up the stern and start on electrics Monday. Mr V is fixin the glitch with the GTX650 for me :). It's nice to be back on the job :D.
          [IMG][/IMG]
          [IMG][/IMG]
          • yz120
            • 233
            #35
            [QUOTE=SJFE;11308][B][I][COLOR="Navy"]I have the first coat of primer drying now. I will only need 2 solid coats to cover it all up. I finished the sanding with 220 grit. I am headed out to fab a new hatch now. As you can see I have 2 coils around the motor. A jacket was out of the question. The cans vented every where.
            iv`e got that same end bell on my losi xxxt:p
            • SJFE
              • 4735
              #36
              Yeah the v2 endbell is the best in the business. The epic shock endbell is nice also. I burned 2 of them up in my abc f550. That was before I learned prop selection and how to test.
              • Diegoboy
                Administrator
                • Mar 2007
                • 7247
                #37
                Wow. She looks good! :D
                • Stealth Assassin
                  • 610
                  #38
                  Just a helpfull hint... Paint or primer Is allways a minimum 2 step process. First, Know your pot life! Lay down a light coat. Let It start to tack up then lay down a slower thicker coat (not to slow)before It dries. etc...
                  On projects where you need to build up with the primer, you can use a thick filling primer like slick sand from evercoat. Depending on temp pot life Is about 45 mins. roughly every 15 mins you can lay a thick coat on.
                  When your done, you have a thick coating to sand to get smooth. works great over rough fiberglass out of the mold without gel coat.
                  • SJFE
                    • 4735
                    #39
                    Thanks Danny :). Thanks for the paint advice Stealth :).
                    • Doug Smock
                      • 5264
                      #40
                      I'm waiting to see the guts. LOL She's looking good Tom.
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • SJFE
                        • 4735
                        #41
                        Frig!!!!!!!!
                        Thanks Doug it did look good @ that point lol. I have had a pain DISASTER !!. I don't really understand why. It was preped right and both colors and primer is the same brand and ment for plastic.. I am just a little more than pissed. Like a smeckle I kept trying to recoat it instead if just accepting it wasent going to cover. I DRED sanding this crap off back down to the primer. After fixing this cluster_ _ _ _ i'm just going to leave it gloss whit and sticker it. I quit.....
                        • Stealth Assassin
                          • 610
                          #42
                          Did you use a degreaser before applying the paint? Also did you get full coverage with the primer?
                          • SJFE
                            • 4735
                            #43
                            By the book on everything. I am stumped
                            • Mich. Maniac
                              • 1384
                              #44
                              if ya havent done anything yet try scuffing that area and re-priming that area again. then scuff one more time and try paint again
                              • SJFE
                                • 4735
                                #45
                                Worth a try..thanks
