Vision FE Tunnel Build
  • Kris Flynn
    #2 Bench Racer
    • 248
    #31
    I forgot to measure, SORRY!! I will set a reminder for tonight!
    • Cat-Boi
      • 304
      #32
      no problem and thanks mate!
      Sandy Squitieri
      www.graupner-usa.com
      • RayR
        @SiestaKey.calm
        • 1591
        #33
        Sandy,
        Hardware arrived today. I will ship to you ASAP.
        Ray
        • Cat-Boi
          • 304
          #34
          Cool, thanks Ray! Sent your check out today...
          Sandy Squitieri
          • Kris Flynn
            #2 Bench Racer
            • 248
            #35
            I hope you guys like the parts, plenty of pictures and feedback please!
            • Cat-Boi
              • 304
              #36
              jawhol!
              Sandy Squitieri
              • Kris Flynn
                #2 Bench Racer
                • 248
                #37
                OK from the TRANSOM to the rear set of screw holes in the servo is 360mm
                Make sure you use a hi-torque servo like the Hitec 5645
                • daveives
                  • Jun 2009
                  • 111
                  #38
                  Some building comments
                  I have found that epoxy dipping does not waterproof an esc, eventually the epoxy/silicon insulation wire joint will leak and kill the esc. I now use "Permatex Sensor-Safe Blue RTV silicone gasket maker" to seal things. It is much better at sealing to silicone wire insulation, just try pulling a gob of it from a silicone wire - you likely cannot! It is under 4$ at Wal-Mart.
                  I now use Traxxas 2075 servos (digital, hi torque) which actually seem to be waterproof (so far). You need to use a servo saver Traxxas #3744 with the servo, or you will strip the plastic gears when you come down sideways.
                  To waterproof a pushrod, install a brass tube with a rubber boot. You can seal the boot to the tube and pushrod with the Permatex, and add an O-ring around the tube/seal by stretching & sliding the O-ring over a larger tube, sliding the larger tube over the boot, and rolling the O-ring onto the tube/seal.
                  I would like to thank Kris Flynn, Alaan, Darin Jordan, and F1tunnelhull for their informative postings which have helped me a lot in my progression of builds.
                  • Cat-Boi
                    • 304
                    #39
                    Thanks Kris! I am using a high torque steering servo from futaba.
                    Thanks for the extra tips!
                    Sandy Squitieri
                    • j.m.
                      • 847
                      #40
                      The traxxas 2075 servo is waterproof.
                      And for $40 your not going to find many waterproof high torque digital servos.
                      Good idea on the RTV gasket stuff!
                      • Cat-Boi
                        • 304
                        #41
                        yup, the rtv does stick better than silicone. silicone is really for bonding glass.
                        Sandy Squitieri
                        • sailr
                          • 7128
                          #42
                          I hate to be dense, but do you have a picture of this? You lost me at ..."and add an O-ring"
                          "To waterproof a pushrod, install a brass tube with a rubber boot. You can seal the boot to the tube and pushrod with the Permatex, and add an O-ring around the tube/seal by stretching & sliding the O-ring over a larger tube, sliding the larger tube over the boot, and rolling the O-ring onto the tube/seal."
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • Cat-Boi
                            • 304
                            #43
                            I have a different set-up I am using, won't leak. just waiting on some parts to come in.
                            Sandy Squitieri
                            • sailr
                              • 7128
                              #44
                              How I wire my Outboards
                              This is how I set up the wiring on my outboards. No need to glue the esc/motor wires or add sealers, etc. A SHORT set of wires is permanently installed in the transom. The ESC plugs into one side and the motor into the other. SIMPLE
                              Mini Cat Racing USA
                              • properchopper
                                rcgoatbuild@snotmail.com
                                • 7708
                                #45
                                This seems like the most sensible, convient solution. I've thought about doing this, then my mind gets stuck on the " too many connectors supply too much resistance" merry-go-round. Decisions, decisions....
