Merry Christmas from my wife to me!!!! She suggested that I theme this build after the two drivers that lost their lives on the Victory 1 may they rest in peace. This is the new Skunkworks 32" Cat. I was fortunate enough to purchase the very first one produced. This hull is very rigid, no need for reinforcement. Just a hair over 2.4 lbs on the scale. I would like to thank Scotty for the hull and may he have much success with this new catamaran. It is a beauty. I have included a few key angles that many of you were wanting.........
New Skunkworks 32" Catamaran
* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Tags: None
Either twin Neu 1509 2y's on 4s or Single Neu 1527 1.5D on 6s.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *
Better give that wife of yours something nice! You have a good one that is for sure!!
Originally posted by tth View PostEither twin Neu 1509 2y's on 4s or Single Neu 1527 1.5D on 6s.
A 1527 in that hull will have more then 1 hp (750 watts) unusable power. You dont need that much however the reason you might want to put that motor in is because you already own the motor. Even a 1521 has more power then necessary and will turn enough prop to make that hull flighty. Setup right a 1521 will get you to speeds where blow overs are regular. Cat's trap too much air. If 70 to 80 is your goal invest in a rescue boat.
JohnChange is the one Constant
John I do also have a couple 1521's. I am leaning towards a twin setup with the 1509's. Only thing is the sponson transom will only accept very limited height stingers. I doubt even MHZ- MTC drives would even work?
Thanks SJFE nice to see you back around.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *
Very nice hull, looks to be same material than HOTR cat'.
I love the top hatch, can you give me the size of the top hatch? Thanks
Not even close, the Skunk Cat is much nicer. This hull is built very rigid. It is nice and light but very stiff. I am at work right now but I'll pull some dim's for the hatch later.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *
Chuck I'll check tonight to see if the SV stingers will fit. Contemplating the Fine Design stingers also. I have a purple one, just have to see if it will fit the transoms. Fella's this boat is awsome. Best quality hull I have seen in a good while.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *
The hull looks even better than the pictures Scotty had posted. I'm hoping that the rest of the hulls aren't far behind if he sold you the original!
