30" cat EVO1
  • CornelP
    • 793
    30" cat EVO1
    Could not think of another title...
    Well, same 30" project, modified drawing. It is about 2cm wider and with a couple of twists in the back, mainly to accommodate the hardware I already have.
    Laser cut in 4mm lite ply (never again, too soft), covered in 2mm balsa (to give some space to sanding). Everything will be covered in fiberglass, filled and painted.
    The inside hull is a sandwich of 0.8mm ply (outside), 4mm balsa, heavy glass cloth. Should be solid and elastic enough for the motor.
    The motor, for now, is my 10XL, but will be probably replaced by a Tenshock 2240/7.
    Same 2mm wiredrive on Graupner K45 (for now).
    The 10XL will be powered by 2 x 5S 3000mAh 20C in parallel, the future Tenshock on 4S (TBA). Previous testing actually showed that 10XL on 6S is a bit too hot (cook eggs on the motor, even on a 42mm prop). ESC will probably be a Himodel 200A, watercooled.
    Motor mount is also home made, still need to polish it a bit.
    I did a bit of modding to the transom, as the mount plate of my hardware is a bit bulky, but it turned out quite ok. Just need the batteries to decide on the internal layout.
  • CornelP
    • 793
    And two more pics:
    • Norman2
      • Sep 2008
      • 354
      Hi CornelP, Looking very very good. Regards
      Norman
      34" Ekos Cat UL-1 Powered
      • CornelP
        • 793
        Getting There...
        Well, after a long holiday, I restarted work on this. Finished the hull, complete with ridepad (still needs a bit of sanding).
        Motor will be for now the 10XL, as the one I purchased is a KD45... I read what Steven was saying about them AFTER ordering... running on a Pulso 100A ESC, 5S2P.
        I borrowed another item from the flyers, the Bowden cable, and it seems to be ok, will see how it performs. Rudder is now sharpened and recoated with epoxy, just need to see about the length.
        The cockpit shape is borrowed from my beloved mono "Wasabi" (the smoothest riding hull ever) and very easy to do. I think that once painted it will look nice...
        Almost ready for paint...
        • CornelP
          • 793
          ...and some more...
          • tth
            • Apr 2008
            • 1600
            I like the mod you did to the transom. It looks nice.
