BBY's 1/8 Pro Boat build
  • RandyatBBY
    • 3944
    This is the start of the build for a Sport Hydro to run against the gas guys. I wanted a hull that I did not care if they got excited and ran me over again. This Pro boat was aquired on RR for the price of a 8L Hacker motor about four or five years ago.
    Hear is the motor that will be pushing the boat. Retail $169.00 from me, so this will be a inexpensive build. Not sure of the ESC I might use a China 180 or 200 model. I have two 40.160 but one is going back for repair.
    Randy
    BBY Racing
  • calcagno45
    • Mar 2008
    • 1050
    Whats the specs on that motor? Looks interesting.
    Great re-conditioning of that hull!
    • RandyatBBY
      • 3944
      Size Outside dimensions of motor 63.29 X84MM
      Cooling chamber dimensions 58X37MM
      Kv 650
      Shaft size 8MM
      The Kv is 650rpm
      Max watts 10,000
      Max amps 175 to 200
      Max volts tested was on 15S and it pulled 8300 watts on a big fan jet.
      Running at 62MPH in a Sport Hydro it pulled a average of 65 amps and spiked to 110 amps
      Randy
      BBY Racing
      • crabstick
        • 955
        holy crap! that is awesome...
        does the motor have a cooling reservoir in that front block Randy?
        Matt.
        www.rcboats.co.nz
        • RandyatBBY
          • 3944
          Yes a big chamber! I will be building the hardware tomorrow. I am going to test the bottom as is in Primer I think that the botorm will need to be modifyed to keep from blowing over at high speeds.
          Randy
          BBY Racing
          • AndyKunz
            • Sep 2008
            • 1444
            Looks like a fun project, Randy!
            Andy
            Spektrum Development Team
            • yurkanip
              • 495
              Any updates? I am looking forward to your build thread, to continue.
              • RandyatBBY
                • 3944
                I am still fine finishing the hull. I sand blasted the paint off the hull and Patched the rough parts with Epoxy resin and Milled CF with a small amount of Cab-o-sil. Then I have been Bonding the surface for the fine finish. I filled the Pro Boat strut mount with the resin and bondo. I probably should have taken some pictures of the bondo area. Sorry I forgot. Durring the finishing I re primer I do have a few pictures of that. I sprayed the top yesterday and the Bottom today.
                Rough spots like this will be bondo.
                Randy
                BBY Racing
                • AndyKunz
                  • Sep 2008
                  • 1444
                  How are you going to paint it (color scheme)?
                  Andy
                  • RandyatBBY
                    • 3944
                    Andy
                    I am still thinking about that not decided yet, It will be run in the Gas Sport class so it is a little open.
                    Randy
                    BBY Racing
                    • RandyatBBY
                      • 3944
                      The build has been on hold for a little while I have a few props comming and I will get back to it.
                      Randy
                      BBY Racing
                      • m4a1usr
                        Fast Electric Addict
                        • 2036
                        Is that a Lobster with the cowling cut back? Awesome paint job!
                        John
                        Change is the one Constant
                        • j.m.
                          • 847
                          Dern... 9 boats and one car in a picture that probably only covers 10% of your shop??
                          • RandyatBBY
                            • 3944
                            Hear is is before my trips to the nats and the saw's
                            Randy
                            BBY Racing
                            • RandyatBBY
                              • 3944
                              I have over 130 boats and 40 to 50 cars. It is packed a collection from 1985 and I hate to sell anything. Oh and that is just my sky light.
                              Randy
                              BBY Racing
