Mystic C5000 M
  • Tuslow1
    • 154
    Mystic C5000 M
    I'm looking for a really good power setup for the 44 inch hull?
    I was thinking along the lines of -
    2 x 1527/1D motors
    2 x Hydra 240 LV esc's
    2 x x447 L and R Props
    2 x 4s or 5s Hyps 6500 mAh LiPos
    I'm very excited to build such a boat and would love to hear your suggestions.
    I've always followed the thoughts of others and have not blown up anything yet, So I'm asking first of all is my setup overkill or do you think it is bound to be a big'ole turtle?
    Hull should arrive Wed or Mon. I can't wait to start posting Pics of the build from box to paint to water!!! And hopefully NO SMOKE!!!
    OK, You Go First!!!
  • RandyatBBY
    • 3944
    You could go the little hotter motors for a twin setup. The 1527 .5Y should be good on 4S, I would not run the 5S on that ESC.
    Randy
    BBY Racing
    • Team FFRB
      • 328
      Over Kill
      I have the same hull set up with twin 1515 1Y's 2200kv running on 4s per side and I am using Etti 150's.
      My plan is to run this set up on 5s per side this week end.
      I do think twin 1527 1D's would be over kill, But would be interesting to see some one try it out.
      Look forward to seeing what you will end up with.
      HOT RODS ON WATER
      • vvviivvv
        • 1148
        Twin 1521 1.5d's on 6s or 1d on 5s for less weight?
        running my hpr115 on 1521's and there alot cooler than lehner 1950/7's
        i believe this is the same as your boat?
        http://www.youtube.com/watch?v=JqV4F-sSVv4 ....
        Uk SAW record holder
        • Tuslow1
          • 154
          thanks guys, I think I will go with the 1521/1D's on 4s X2
          I think 40+K rpm's are great and I will play with props for speed till things get close to the magic KABOOM!!
          I was thinking x440's as a starting point.
          Anybody have a idea of what the amp draw would be on that setup?
          OK, You Go First!!!
          • vvviivvv
            • 1148
            i don't know if this is correct but about 104 amps constant and 200ish max?
            • Tuslow1
              • 154
              Thank you soo much vvviivvv. I know everyone who thinks highly of Mystic hulls will bash me for this, but I want to use HiModel 200 amp cheapy esc's. I just wanted to make sure I wasn't going to kill them right off the back!!!
              OK, You Go First!!!
              • vvviivvv
                • 1148
                can you post a link to the hi model's? i need 2 cheap brushless esc's for my scale boat saves me switching my good esc's around between boats
                • Tuslow1
                  • 154
                  If I get smacked on the back of the head for this, I will start shooting spitballs at you!!!
                  HiModel GX Seires 200A 4-8S Electric Speed Controller W/BEC Type GX-200A-BEC from manufacturer HiModel, in category Brushless Speed Control (BL ESC) - Air/ Helis, Electric Speed Control (ESC).
                  OK, You Go First!!!
                  • Simon.O.
                    • 1611
                    IF you are going to go the low cost way with the ESC, I do, then also take a look at the Mystery 200A available on the bay. They are a lot lower in cost than the HM unit and I would suspect just as good.
                    I use these and have killed a few due to serious misuse or severe water ingress.
                    My latest one is now well water proofed down onto a etti cooler plate.
                    Just a thought.
                    • Tuslow1
                      • 154
                      thank you Simon,
                      Truth be told I just know they can sell us a esc that will not blow, it won't kill anything and won't let anything die. All of that for the low low price of about $10.00 a unit, and before anybody gets ready to disagree I ask you my fellow boaters to think back to the days of the all mighty 8-track player, cassette recorder aswell as a cd player... they all started off huge in size with a huge price to match and now that they have pulled our chains long enough they have given us the ultimate music device that fits in the palm of your hand and holds more music then you can listen to in 3 yrs of back to back play. Think about it...
                      OK, You Go First!!!
                      • Tuslow1
                        • 154
                        Hull came in wed. and it is everything I didn't want!!!!
                        I ordered JBS decalls but that don't matter,
                        I was going to order a small and large hull aswell, but not now!
                        I don't even know if I will complete the boat, because.......
                        It Is Fuggin Yellow!!!
                        sure they said send it back and we will send you out a white one, but why must I come out of pocket to correct someone elses mistake
                        OK, You Go First!!!
                        • Boatman
                          • 875
                          I'm tellin ya. I posted a while back somewhere that MHZ is loosin it. Send them a complaint and all you get is an auto responder. Their phones dont work half the time and their products are becoming even more odd ball hit and miss. Too bad about the hull but hopefully you an make it work. Still a pretty hull
                          • RandyatBBY
                            • 3944
                            You were going to paint it?
                            Randy
                            BBY Racing
                            • Tuslow1
                              • 154
                              True, I was going to paint it. But I got the JBS Stickers so that the painter could use them as a guide to paint them on and use my name KES insted of JBS. Painting the whole hull white is a waste of time and money, for any little scratch will reveal the boats true colors. So the only thing this hull is good for is a Miss Geico Rep. By the way, I hate Miss Geico!
                              OK, You Go First!!!
