16" Balsa Tunnel Hull
  • CornelP
    • 793
    Hi everybody,
    I started to build a tunnel hull, based on plans on the net, I believe it is the tunnel Shell or Castrol type... did not save the title
    I changed the size to something smaller, as I wanted to use some leftovers from other projects (materials & equipment).
    Sponsons and tunnel are two layer balsa, glassed (still curing...). Cover is also curing, 1mm steamed balsa, covered with 2 layers of light glass cloth.
    Motor is a Turnigy 2445, going to a Graupner flex and home brewed hardware.
    For now the ESC is a Mistery 30A, with a Turnigy 3S 1500 20C Lipo.
    Couple of questions for you guys:
    - is the depth of the tunnel enough? Now it is15mm at its highest.
    - will the motor be ok with this hull?
    I am also thinking to cheat a bit and do sort of a fake outboard, by using the part you see in brass. Should give me the steering from an outboard, on a smaller scale.
    Waiting for suggestions...
    Cornel
  • NEW222
    • Sep 2009
    • 11
    Great looking little unit you got going there. Will be following.
    • CornelP
      • 793
      You have an email :)
      • gto0209
        • Dec 2009
        • 5
        Do you have a pdf of these plans?
        • nauti-tucu
          • 26
          Hi:
          Some news about it?
          • CornelP
            • 793
            Not much... it turned out too heavy, so I have to redo the hull. It's on my list, probably at number 4...
