32" Deep Vee
  • Lasse Baardseth
    • 76
    32" Deep Vee
    Here is my new boat
    The hull is from ebay, 580L (9) from OSE and ESC from Hobbywing.
    The boat will be powered by a 6s lipo.
    Hopefully i will be able to test it soon, but here in Norway it is around 32 farenheit rigth now
  • Rumdog
    • 6667
    You may want to support the rear of the motor. It is a heavy can! Does the hull flex easily in the motor mount area? If so, you may want to reinforce the area with some fiberglass or cf. Let us know how that esc holds up on 6s.
    • Rumdog
      • 6667
      Also, if you don't already have one, you may want to get another lipo. 6s2p will feed that setup more efficiently than a 1p setup. Plus your runtime will increase considerably. Good looking boat by the way!
      • Lasse Baardseth
        • 76
        Thanks for the feedback.
        I have reinforced the hull in the critical places.
        The motor has a support spons under.
        The 6s1p is from my T-rex 600 ESP, i have four of them and was hoping that i could use them.
        Does enybody know what timing i should set for that motor on the ESC?
        • ozzie-crawl
          • Sep 2008
          • 2943
          o timing
          • Lasse Baardseth
            • 76
            I have now tested the boat and the BEC stopped working after 1st. run I know i should have used a separat BEC, but the ESC were supposed to handle it?
            I have now returned the ESC for a full refound and i am looking for a different ESC.
            I think maybe a HV ESC is the way to go?
            I would like to be able to run 8s in SAW runs.
            But now i am confused about what ESC to go for?
            Any input is appreciated
            BTW: amp draw was 98A and 2300Watts with prather 220 prop, speed 40mph.
            Timing 0 (i think that is too low)
            • Lasse Baardseth
              • 76
              what propells do you suggest for my boat?
              I am thinking of buying 4 propells.
              • Jeff Wohlt
                • 2740
                I have never run a BL motor at 0 timing. I would at least go to the first step whatever the ESC says.
                www.rcraceboat.com
                jwohlt5362@yahoo.com
                • westbeach
                  OSE Rocks!
                  • 969
                  M645 or X645 detongued, X642. That what I run on my DF Storm. I would try ABC or Prather. I believe they are a higher pitch props than Octura's.
                  HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
                  • bustitup
                    • 3072
                    which prathers?
                    215 225 230 240 245?
                    • Lasse Baardseth
                      • 76
                      I thougt about X642,x645,x447and prather 230.
                      Do you think they will cover my need
                      • westbeach
                        OSE Rocks!
                        • 969
                        You will need to research ABC or Prather. I merely suggested them as I have heard that they are of higher pitch than Octura's. If I had knowledge of them they would be listed as the Octura's.
                        Originally posted by bustitup View Post
                        which prathers?
                        • westbeach
                          OSE Rocks!
                          • 969
                          Definitely try the X642 and 645. But have it detongued.
                          • Lasse Baardseth
                            • 76
                            Detongued? How do i do that?
                            • westbeach
                              OSE Rocks!
                              • 969
                              Basically having the tongue removed (rounding off the protruding part of the blade) at the leading edge. The tongue is the first thing that bites. This diagram shows what I am talking about.
                              http://www.offshoreelectrics.com/ima...op_diagram.jpg
