Help with my HOR32 needed...
  • KillerDave
    • 370
    Hi guys,
    I am new to FE and after my second run on Li-Po's, my HOR32 has suffered a fire.
    Last week was it's first trip out with the Li-Po's and I had a grin as wide as the Atlantic! She was flying!!! Over 60Mph I'm sure!!!
    This week, I took it out with a GPS and not only was it so slow, but after about 2 minutes there was a thump sound, the bow between the sponsons split open and smoke was bellowing out, she was on fire!!!!!
    So, If anybody can help, please do leave a note?
    Many thanks....
    HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
  • domwilson
    • 4411
    Do you have pics of the damage? Perhaps you can repair it.
    Government Moto:
    • Eodman
      • 1285
      You will need to supply more info
      Mono or Cat
      Battery size c and mah rating
      Motor size
      Esc size
      prop size
      We did it with a Bang!
      Cats Are Where It's At!
      • domwilson
        • 4411
        Here is the info. from one of his previous posts.
        It's a HOTR 32" Cat
        Feigao 12L
        Etti Navy 125 ESC
        2x 3S 5000mAh Li-Po's (6S)
        TFL Hobby Rudder fitted with an Octura skeg
        Prop Shop 40mm prop but I don't know the pitch
        Government Moto:
        • KillerDave
          • 370
          I have to get ready for hockey now so I will do it later (3 hours or so)
          Thanks for stepping up though!
          • eboat
            • 726
            Were the lipos charged and balanced ?
            • Steven Vaccaro
              Administrator
              • 8932
              The 12L is a 4s motor. On 6s it probably over heated the motor or over amped the esc's.
              Steven Vaccaro
              • 785boats
                Wet Track Racing
                • 3423
                From a post on the 'Head of the River Cat' thread, it was a battery that ignited.So I guess you over amped the batteries. What was the C rating on them & what brand.
                Cheers.
                Paul.
                  Sorry about the burned up model! Like Steven said, the 12L should never be used with 6S in direct drive. It clearly over-amped the ESC and likely damaged the cells as well in the previous run. That would explain why it seemed slow on the final voyage - either the ESC or the packs or both were previously damaged. We'll need to know what actually burned up to help much more. Pics would be good.
                  • KillerDave
                    • 370
                    Cheers.
                    Paul.
                    I did ballance charge them and the C rating is or was 15... this should make them out to be 75 amp batteries, I don't think I would be drawing more than 60 amps??? Correct me if I am wrong though......
                    • KillerDave
                      • 370
                      I have taken a load of pictures but they are too big to put on here, I will take more tomorrow at a lower resolution and see if that works....
                      What do you want in the pictures?
                      • domwilson
                        • 4411
                        Damaged parts for sure. Hull damage. Backend of the boat. Side view of the hull, particularly the strut and rudder. Inside pics with the battery placement.
                        Government Moto:
                        • domwilson
                          • 4411
                          If you are using Windows XP you can open up MSPaint. On the menu, select "Image" then from the drop down menu select "Attributes" Then change it to 800 and 600. Then save the image to whatever name you want as a .jpg.
                          Government Moto:
                          • KillerDave
                            • 370
                            Here are some pictures of the damage....
                            • KillerDave
                              • 370
                              And some more....
