32'' cata build HOTR
  • elvish
    • 125
    Received the hull today,
    And coming home after work, started the build
    First, no need to get our hand dirty, I rather keep the gelcoat clean, so Mr. Newspaper did his job
    What should I choose? Carbon or carbon Kevlar?
    Started placing the layer in to see how it fits
  • elvish
    • 125
    fit on the back
    And the fit of the coal
    Epoxy is in, had a hard time with my fat fingers
    The back of course is getting a second layer
    • elvish
      • 125
      epoxy on the coal
      • elvish
        • 125
        Some parts
        neu 1512 2d
        feigao 8xl
        etti 150amps opto
        elogger v3
        aluminium servo mount
        • Alfa Spirit
          • 2131
          You don' t loose your time . What kind of rudder and strut did you buy ?
          I bought this one from HOTR
          • 785boats
            Wet Track Racing
            • 3169
            Nicely done.
            I didn't notice it in the text or the pics, but did you run a strip of mat all the way down the sides up to the front to strengtheg the join of the deck & the hull? This is where the cracks first start to appear
            Look at this.
            • elvish
              • 125
              Came home from work, too tired to work on the hull, plus no more epoxy, have to get some tomorrow.
              This pictures better shows how far the carbon layer goes, from the front opening of the coal, it’s about 23-25cm , I think it covers the cracks.
              the coal, cut off the edges, still needs a thin layer of epoxy , for the finish
              also I started working on the props,
              I’ll get more time tomorrow
              Once the carbon reinforcement is ready, I will need some information, on the motor mount position, the strut height, and of course all the other information that will come up
              • Alfa Spirit
                • 2131
                Nicely done.
                Look at this.
                Good idea
                Thanks
                • elvish
                  • 125
                  Bad news today, my etti 150 exploded caps running on my mono...
                  I contacted etti, probably will get a response Monday....
                  • 785boats
                    Wet Track Racing
                    • 3169
                    Have you figured out Why?
                    What is the setup & the circumstances of the failure. Looks like a bad one. Just so no one else does the same thing.
                    Paul.
                    • elvish
                      • 125
                      no idea, everything was fine 3 min, even my temps were quite colder than normal.
                      I was running 3cell zippy 4000 mah 30c with my neu 1512 2d, on a x440 .
                      No extra caps on esc. I think that was the problem, thank god the hull didn’t break….
                      Never pushed the esc more than 90 amps .
                      The speed control doesn’t seem to have any damage on the inside.
                      • Rumdog
                        • 6453
                        If you add the cap board to it, it will still work. That is unless there are other issues.
                        • 785boats
                          Wet Track Racing
                          • 3169
                          Could the batteries have been struggling to deliver the voltage required after 3 mins of running & with that current draw leading to that infamous ripple effect blowing the caps?
                          Someone more experienced than me will have to help you with this one.
                          All the best.
                          Paul.
                          • elvish
                            • 125
                            yes, that is what a person on the lake told me, but I still think it would be cautious to wait for a response from etti, either way, thank god for the *!***!***!***!**ty weather in Paris, no temptations :)
                            As for the cat build, got some epoxy today, will update something tomorrow
                            All I know is that it happened on a acceleration, actually, as soon as I pressed on the gas, the boat didn’t even start, it just blew off
                            • elvish
                              • 125
                              Hello for a small update,
                              The epoxy I got, is min 24h which makes thing very very slow....
                              So I tried out the motor mount, and in my biggest surprise, the motor kuhler touches the ground
                              OSE's kuhler is a MONSTER
                              So I grabbed a second pair of epoxy plates, and added some balsa and created a carbon fiber sandwich to raise the level.
                              The only thing is that for the hatch to close and have some space, is to be positioned here:
                              Which is not bad I suppose,
                              Any comments on the best position for the motor is welcome
