Octura s/b x646 prop
  • Tony
    • 420
    Would this prop work with a 37" cat hull?
  • z400
    • 1333
    ....Why did you post this in the BOAT BUILDING section?
    This needs to be posted here- http://forums.offshoreelectrics.com/...isplay.php?f=2
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
    • Simon.O.
      • 1611
      Either way there needs to a be lot more info.
      Motor?
      Cell count ?
      ESC ?
      Anticipated run time or speed ?
      Once we have all of this then we can say if the prop is suited.
      fwiw as a saw prop on a low wind XL it will scream.........and smoke.
      • Tony
        • 420
        Motor?
        Cell count ?
        ESC ?
        My bad, i should have posted on the FE Q&A thread.
        Motor: KB45 8XL 1600kv
        Batt: 6s1p lipo
        ESC: Himodel 200amp 3-7cell (no bec)
        Run time: 4 minutes or less
        This setup is running with x445 prop in a 37" cat. Just want to know if x646 prop will work or not.
