Sprint Cat .40 Winter build
  • crabstick
    • Jul 2008
    • 954
    36 inch sprintcats rule!!!!
    Matt.
    www.rcboats.co.nz
    • Raydee
      • 1603
      I am just real lazy and couldn't get motivated this winter to build anything. I have a NEW Phil Thomas SS 21 hull that I bought last summer still sitting in the corner. I bought the SC hull in October and was going to build it over the winter and it just never happened.
      This year I am going to do things a bit differently than years past. Instead of spending a ton of money to sport boat I am going to go in the other direction. Cheaper cells, and ESC's for me. I am going to stick with Neu motors though ......until I find a cheap motor that compares....if ever. I am planning to use a Swordfish 240 ESC in this hull with some Turnigy packs.
      Team Liquid Dash
      • Rumdog
        • 6453
        Yeah, looking good man!
          • 9479
          great job on the cowl, looks very clean..
          • Jeepers
            • May 2007
            • 1973
            Raydee very nice build as usual your work is excellent.
            On the other hand AM made an UGLY HATCH for those boats, seriously. If it was mine I would keep on cutting it up.
            • Raydee
              • 1603
              Yeah I hate the hatch, I am hoping someone comes up with something a little more eye pleasing since this boat seems to be so popular.
              Team Liquid Dash
              • Raydee
                • 1603
                Ok the boat is ready for testing, if everything works out right I will take it all apart and paint the hull mid summer........OR maybe next winter
                Team Liquid Dash
                • knpc
                  • 566
                  I'll be interested to see how it goes as I'm still trying to work out the bugs since switching to the same setup. I think I may have figured it out but I'll find out in the a.m.
                  What props are you going to try on it?
                  Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
                  • Raydee
                    • 1603
                    I have a 447, a 447/3 that I will try first. Then I have a 450, 452,455 to try along with all those in three blade if I remember correctly.
                    Team Liquid Dash
                    • Rumdog
                      • 6453
                      I don't know what everyone's beef is with the turbine hatch. I personally think it's awesome. I like the fact that it is different. Just a little modding to make it water tight is all.
                      • Rumdog
                        • 6453
                        I had bad results when I didn't load the motor enough. Didn't try any 3 bladers, but under 52 mm was a dramatic speed loss and no less heat. This motor will spin big props!
                        • Raydee
                          • 1603
                          Yeah the Y winds in general Love big props. I was running a 637 in my Sport 20 hull using a Hacker 7XL motor and it ran pretty fast. I then switched to a Neu 1515 1Y and with the same prop lost at least 10mph and it ran hotter. I scratched my head for a while and after talking with Brian Baas he told me that I need a throw a bigger prop on it to properly load the motor. The hull is insane with a 645 prop and still runs pretty cool. I would have never even considered a 45mm prop on the sport 20 but the Neu motor loves it. I imagine the 1527 1Y will need a nice size prop to get it going, I was running up to a 450 with my 1527 1.5D so I wouldn't be suprised to see a 460 or a 457/3 prop for the 1Y. All the cats I have owned in the past loved 3 blade props so I will be trying them on this hull as well.
                          As far as the hatch goes, I just don't think it looks right on a cat but to each his own. I have plans to buy the clasic hatch and cut it up and made something more "Cat like".
                          Team Liquid Dash
                            • 9479
                            interesting how these motors like big blades
                            • 10gauge
                              • Aug 2007
                              • 281
                              Hi Ray, the build looks nice. I bet the paintwork will turn out exceptional as usual! BTW, I see that you're set on the 1527/1Y. Do you plan on using the 1527/1.5D for this hull? I've been dragging my feet on building several projects, including this one, but I do have a 1527/1.5D thought it would be nice to use for 6S2P.
                              Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
                              • Raydee
                                • 1603
                                No I sold my last 1.5D, fast motors but I think the 1Y will be almost as fast and swing a larger prop at the same time as keeping the amps lower. I wouldn't mind this hull in the mid 50's with a little bit of run time. I seem to keep the same pattern with all my hulls, push them as hard as they will go for a very short time. I am trying to change my ways so selling my HOT motors is the only way I will do that. I am actually going to try one of those 1717 Neu/Castle motors in my Phil Thomas SS45 hull and another Ice 200 controller IF this one in the Sprint does the job.
                                BTW the 1527 1.5D motor in my 36" Hydro with 6s2p was a very fast setup, just make sure you have a controller that can handle the amps. That setup ate my Hydra 180HV in a very short time.
                                Team Liquid Dash
