Hpr06
  • malibu1
    • Sep 2009
    • 74
    Hpr06
    Hello everyone,
    This is my first post here, and am really new to the FE scene. I have been lurking for the last couple of months and trying to descide on which hull I wanted to get for my first Cat. Well, earlier in the week I ordered an HPR06 with the HPR drives and hydraulic rudder set up. I figured this project would keep me busy during the cold winter months. I am actually going to do a scratch build also once I see how the HPR turns out. Hanspeter said it would be about 5 weeks before he gets to my boat so I have some time for picking up materials.
    What would be a good start for motors? I was thinking some 580s or Neu 15XXs? I want to run 5S or 6S batteies and was thinking of castle 120HV or the race Etti for speed controls. Of coarse, cheaper is always better but I don't want to skimp on the good either.
    Also, what thickness of carbon fiber is everyone using for motor mounts and such?
    Well back to searching I go!
    Thanks!
  • Gerwin Brommer
    • Dec 2008
    • 928
    Hi.
    If you wanna make them yourself, use 2.5 or 3mm sheets.
    IMO the 580's are overkill, to much torque.
    With 540's you can reach 60 mls on 6S.
    Neu's would be my choice.
    • westbeach
      OSE Rocks!
      • 969
      Malibu,
      Welcome to OSE. Firstly I would go with the C/F kit that Gerwin has provided the link for. It comes with the transom doubler plates and the motor mount. The motor mounts will fit the Neu motors. And the transom doublers are a must in the HPR's. They are not reinforced from Hanspeter. The transom doublers will require some work to fit tight on the inboard corners.
      Neu motor would be a definite choice of motors. But it depends what your plans for this cat would be too, such as sport running or speed? If you look under HPR07, KevinLew has a thread on his, but he runs for speed. His setup running double rudders and strut style drives is a great idea for building these HPR hulls as the transom is at a premium for hand space to work in. You will see once you get your's.
      Another important thing is to start sourcing your drive shafts, you will need a left and right turning shaft, and equally some left and right turning props. These are available in a few sizes only. Most run X442's LH/RH. With some exceptions.
      HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
      • Gerwin Brommer
        • Dec 2008
        • 928
        Fortunately Malibu bought the scale drives and rudder ;-).
        Very important : try to position the drives as low as possible and as close as posible towards the tunnel. Yes, that's a bit of labour, you'll have to remove some material from the inside
        of the sponsons to be able to position the drives right.
        If I had to build a HPR06 again (that would be my 3th or 4th '06-build) I would give it a fully closed bulkhead. last weekend I saw a 06 flipping, the front of the right sponson
        cracked open at the seam.
        Westbeach : outboard BL (avatar) ?
        • westbeach
          OSE Rocks!
          • 969
          Gerwin,
          Avatar, is my new HiJack 3.5 outboard motor mount fully adjustable. This mount is so nice, I might have to wear it as a necklace or make it into a ring or something.
          I got a DPI abs plastic tunnel from the buy n sell on OSE. I figure I will start with this hull, with some c/f cloth reinforcement on the lower hull section. Run with the UL1 motor and esc to whatever speed it can achieve. Then upgrade to a WOF hull later on.
          The scale drive/rudder is very nice, but a lot of though will have to go in before he starts any layout/drilling holes. I took the time to do mine, and everything fits good. But space is at such a premium specially with limited tools/experience. I have the experience working with feel and no see type situations working on commercial aircrafts. But it was still an ordeal installing the screws for the upper mount for the arnesson drives.
          If I were to do another cat, I would definitely take Kevin's route. And I am sure that setup would yield a great SAW boat. BTW what type of drives are the guys using for SAW setups on the cats in Europe? I don't think anyone has asked this question yet??
          • malibu1
            • Sep 2009
            • 74
            Thanks for the replys!
            As of right now, I am just going to use this Cat for sport driving. Not looking to build a SAW but, but the faster the better:) I think something that goes close to 60 should be perfect and not get to wild.
            I will order those carbon parts from ae and re-enforce the transom. Being Hanspeter has not started my build, think he would reinforce that area if I asked him? Oh, I did order the Carbon Fiber boat, not sure if that makes a difference or not. He's going to sign his name on the Carbon somewhere in side for me:)
            Do you guys have a good source for the drive shafts? Are they a wierd size?
            For running 60, what Neu's would you guys look at?
            Thanks,
            Mark
            • Gerwin Brommer
              • Dec 2008
              • 928
              You can ask Hanspeter to include both the flexshafts !!
              For fixing the uppermount of the drives : easy : make a piece of aluminium with 4 holes in it.
              Use the drive-uppermount as a template. Cut thread in the 4 holes.
              No messing around with 4 nuts in a tight space :-)
              Screw the mount in place and then glue the alu piece in the hull.
              If you make that alu contra-mount a bit larger you also have a nice overhang-reinforcement :-)
              • malibu1
                • Sep 2009
                • 74
                Yes! A nut plate would be a great idea. I will have to do that.
                Is there anything else that I should get from Hanspeter other than the flex shafts. Does he sell a front bulkhead? I am guessing that the hull comes with the clear windshield material and as shown on his site?
                If I send more money, I want to get everything from him at once. It's kind of hard to send money to a swiss bank account from the states! Especially where I live. Had to go to three different Bank of America's before I could find one that knew how to wire money...
                • westbeach
                  OSE Rocks!
                  • 969
                  Gerwin,
                  Is this how you have attached the drives upper mounts to the hull? That was my first idea, but because the inconsistent layup inside and the seams of the upper and lower hull, I threw out that idea. The plate would ride against the radius of the transom and not sit flat.But maybe it was just the layup of my hull?!
                  • westbeach
                    OSE Rocks!
                    • 969
                    Mark,
                    Neu 1527's.
                    Thanks,
                    Mark
                    • Gerwin Brommer
                      • Dec 2008
                      • 928
                      Westbeach :
                      First step would be to make the working surface flat.
                      In my own 06 i simply glued the nuts into the hull.
                      You also could give the nutplate the same radius of the transom.............
                      Nope, Hanspeter has no bulkheads.
                      • Xcesive8
                        • Jul 2009
                        • 439
                        Gerwin, very interested as to why you think only Scale drives are the way to go?
                        Have you been present when a HPR was running a setup like Kevins 135..?
                        Do you know of the pros and cons of both?
                        Please fill me in and maybe give malibu your reason for heading in this direction?
                        Cheers Ryan
                        • Gerwin Brommer
                          • Dec 2008
                          • 928
                          Ryan.
                          I don't say hpr hardware is THE only hardware for that hull.
                          But as the hpr's are scale hulls it's nice to have scale rudder and drives.
                          And the hardware is top of the line.
                          ALL recordbreaking hpr's i've seen are running with hpr hardware.
                          Whatever kind of strut/drive/trimm your using, it doesn't matter that much.
                          The only important thing is where the prop is, at what height, what angle, and how far behind the transom.
                          • Xcesive8
                            • Jul 2009
                            • 439
                            Oh ok..
                            Yeah i tend to agree with you, it does look nice with the scale hardware.
                            Ok thank you for setting me clear on that
                            Just had not really herd anyone talk about the difference in drives on these scale cats, i thought there may have been other reasons.
                            Aprreciate the reply
                            Quote:
                            Originally Posted by westbeach
                            Mark,
                            Neu 1527's.
                            Hmmm.. HPR06 with twin 1527's .
                            If only chacing 60mph, isnt this a lil to much motor?
                            • JCAustralia
                              • Jul 2008
                              • 363
                              Hi guys
                              I'm building a couple of cats at the moment and enjoying every moment of it.
                              The HPR cat seems to be the ultimate cat for a builder
                              Gerwin do you have any pictures of your cat you'd can share?
                              Cheers
                              JC
