Hpr06
  • vvviivvv
    • 1148
    #121
    Originally posted by vvviivvv View Post
    I'm just in the process of designing a drill jig for the rudder
    i copied the design from some pics for my battery mounts,
    Dang windows is hard to use, im a Mac lover although i have vista installed on my Macbook pro just for school cad projects... would be much easyer if my school would fork out the £400 for the mac version
    Back on evil Vista created this as a template for mounting the rudder, does this match up with every one?!?! i dont know if ive done this right....
    why is vista so horrible when i upload from mac there nice pictures!!
    Uk SAW record holder
    • elvish
      • 130
      #122
      too small , cant read the numbers on it.
      • vvviivvv
        • 1148
        #123
        Sorry im just going to reboot in mac osx as vista is taking the mick should be sorted in 5 mins.....
        • vvviivvv
          • 1148
          #124
          attempt 2..
          well i can read it
          • elvish
            • 130
            #125
            Do you have epoxy in front of the sponsons? Mine looks quite a lot; I have at least 3, 4 cm of epoxy in front. Good for minor shock, but in case of a hard crash, I don’t know if it may do more damage.
            • vvviivvv
              • 1148
              #126
              yes i do but id say 2cm max... its because ive heard of them breaking through the boxes at front... at least i know if i got running into another boat's side at 100mph ill come off better
              • elvish
                • 130
                #127
                The diameter of the center hole is 15 mm but between the two small 3mm holes vertically the distance between the two is 12mm and not 15
                • vvviivvv
                  • 1148
                  #128
                  i new it didn't look right, have to re-draw the whole things thanks to my best friend Vista also any ideas on getting it 1:1 scale with the measurements i put on it?
                  this didn't work
                  • elvish
                    • 130
                    #129
                    You know the dimensions of the block, 24mm X25 mm
                    For the middle hole, on the horizontal, 5mm space, on the vertical 4.5mm
                    The big hole has 15mm diameter
                    The 4 small holes have a diameter of 2,5mm (3mm screw)
                    Vertically the distance of the extremity and the center of the small holes is 4,5mm
                    Horizontally the distance of the extremity and the center of the small holes is 3.9mm
                    You can do it the easy way, paper tape
                    And you draw the wholes with a pen or pencil, and then you take the tape of and apply it on the hull.
                    • vvviivvv
                      • 1148
                      #130
                      well this is what i came up with dang im tired had too much of that russian standard vodka might come up with annother version dunno
                      if it cant be read.. ill re boot in mac
                      • vvviivvv
                        • 1148
                        #131
                        about to order my battery's, would PolyQuesr 5000 XQ 6S 22.2V 5000 (constant) 150.0A (burst) 300.0A be suitable was going to get hyperion g3's but too many mixed opinions.
                        • malibu1
                          • Sep 2009
                          • 74
                          #132
                          I just recieved two Turnigy 6S 5000mah 40-50C batts from Hobby King. They sure look big. Hull is still at the painters so I am not sure how the fit is yet. I figured I would try the Turningy batteries and if they don't work so great, I will get higher quality batteries. I think I paid about 90 bucks a pop for them.
                          • wolf IV
                            • 1050
                            #133
                            Just ran the 4's 5000 mah 40-50c's this morning and they went out pre-heayed at 110 deg. And came in at 110 deg!!! They are amazing!!!!!!!! There is absolutely (no ) need to waste your money on name brand batteries when tunigy 's perform better than my poly quest set's!!
                            http://www.youtube.com/watch?v=e-npTLBHefY
                            • vvviivvv
                              • 1148
                              #134
                              it just doesnt seem right to have one of the best hulls with some of the best gear then Chinese lipo's i do have some Chinese lipo's for some of my lower powered set ups but will they last 50 runs at 100 amps maybe 150? i don't know what my motors are going to pull... the polyquest lipos are about $250 each so i could get 2 from china for the price
                              heh i will be saving 600 grams if i get the polyquest lipos
                              • wolf IV
                                • 1050
                                #135
                                Its up to you... I have over 3400.00 $ in lipos and started exsperamenting w/ the turnigy's.. Love them!!!!!!!!!!!!!!!! My set up is running at 200 amps consistant per side in the upper 60 's the entire run!
