wish i had bought lehner's, that way i could of copied a set up and used the same volts as them, at the min i can't find any one with the same set up as me thats got it running and got some temp idea's + speeds + amps . everyone on this site is using a diff set up!
Hpr06
Dave Im building a twin powered HPR
Good news....the motors are in and AndyG sent the to me today should have them thursday.
So now to see how these Hydro/Tunnel mounts fit, they look good, simple and light.
vvviivvv the good thing about this hull is you can running one of ten setups and still get a very good result, all run 116 kph most run to an average of about 140kph not bad!!
On with the build!STUFF NITRO GO LIPO
FASTELECTRICS.COM
OFF-SHORE-ELECTRICS.COM
INVENTOR OF LITHIUM CELLS:bowdow
Installed the watercooling, rudder last night the drives I uploaded pics of and the mounts I can take pics of, I've been mega busy lately and where in the airport now... My dad is going back to work so the build was fairly rushed in the endHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
Uk SAW record holder
well tbh got my batts to buy and mount too
i have one quick question, i want to run my props inward, the drive line + prop is the port side system is this right? i always snap/unwind shafts because i get this wrong
other pic is my watercooling - not bad for a 1st attempt imo.Attached FilesHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
epoxied the carbon plates, drilled the holes, and grinded the epoxy for the bolts to mount.
the best investment ever for a 115 builder....
i dont know how i would of got 1/2 of the bolts in there without themAttached FilesHpr 06 / 09 / 150 /185, Mhz Skater H45 hydro.
Gosh you guys are way ahead of me! I have been watching here every day but have not had a chance to get started on mine yet. I have everything for the build now except for the speed controls and some syringes. I think I am getting tired of looking at speed controls. I think I may try the 240HV Hifi's when Steve gets them in. Thought about castles but am scared of them after reading all the posts.
installed the first drive today
had to drill the hull a little to get it to fit correctly.
I filled the dents and hole with black epoxy so you can't really see that its filled.
