Sea Rider 2000 15.5" cat thread
  • befu
    • Aug 2009
    • 1064
    Well, as I got into this hobby again with my fleet of Pro Boat Mini-V’s for the kids, I also impulse purchased one of the Eba_ SeaRider 2000 Catamarans. The hull is about 15.5” long (almost 400mm), has a 30mm prop on it with a nice brushless motor. The speed control is water cooled and the shrink wrap is sealed with a clear putty (like shoo goo).
    It was shipped in its original box with pictures on the side just like it came off the shelf! Concerning, but it was bubble wrapped and is a small strong hull, so it made the several thousand mile trip just fine. Box is scrap though!
    The hull looks decent, actually fine for the price paid. The gelcoat is good and the hull is strong enough. I know that from running it full speed into the rocks after it submarined on me, but more on that later. One thing I did notice is that both running surfaces have a small hook in them. Not sure if this is designed in or if it is a result of pulling it from the mold too early. If anyone has one and can check it, I would like to know before I flatten out mine.
    A couple things about this boat:
    The clear lid to tape on for sealing the hull fits odd because the motor sticks up above this surface. So I used a heat gun and put a “bubble” or hump in the clear lid so it now fits without being force deformed over the motor.
    The water outlet was a machined aluminum piece, not the hose sticking out the side as shown on Ebay.
    I took the turn fins off. I am only running it on 2 cells and it is rated for 3. So my speeds should be low enough that turn fins should not be needed.
    I removed about 12” of water line from inside the boat as they were very long! Better too long than too short.
    I replaced the drive tube. The original drive line did not seem right. The drive cable is .093 with a 3mm prop shaft. The Teflon liner seemed like it was way too loose, maybe for 1/8” or 3mm drive cable. The shaft also ran in the Teflon tube unsupported. Either way, I drilled and reamed the aluminum stuffing tube out to 3/16”. I then securely epoxied this into the hull as it came right out while drilling it. Into this, I put a piece of 3/16 brass tube from the inside of the aluminum tube to just in front of the strut to hold the new .093 octura Teflon liner. I soldered a ½” long piece of 5/32 brass tubing into the end of the 3/16 tubing and left a ¼” sticking out. This is the correct size to slip into the brass nose piece on the strut. So now the flex cable is securely supported from the collet all the way to where it enters the strut. A simple thing to fix, the drivetrain is now secure and spins freely!
    I also added foam into the front of the hull and the hatch cover.
    The rudder push rod was not sealed either. Being short on rubber boots and impatient, I put some Vaseline on the pushrod and then sealed it inside and out with a dab of clear silicone. Let it dry and now it slides through the silicone, works pretty good.
    Driving
    I am running a 2s-2200 battery in this boat in the recommended place. The COG is 4.5” in front of the transom which seems pretty far back, but this is 30% on a 15.5 hull. I tried a 27mm prop from OSE but this did not work. Once on plane, it was great but it was really hard to get it onto plain. So back to the 30mm prop. The 30mm prop from OSE looks and measures identical to the original Sea Rider prop.
    Even on two cells this thing jumps right up on plane. Now I need to figure out how to adjust the strut. The pond I ran on twice is fairly large (100 acres?) Both times the wind has been blowing towards the shore and been choppy. Waves in the 1.5” to 2” range I guess. Not real rough, but for a 15” boat this is choppy.
    First time with the strut parallel and at the bottom of the ride surface it was hopping real bad. Bow up and 45 degrees and then down, up and down. Tried a few places and angled prop down to try to plant the bow some. It worked but too much and it would hook the nose and spin.
    Twice I submarined it. Driving full speed it would bounce and just disappear under water. You could see the yellow and white color disappear down into the depths with the prop still pushing it! About 10 seconds later it comes back up and off it goes! Well, a few minutes later it happened again. And nothing. 10 seconds. Still nothing, did it sink? 20 seconds…. It can’t sink, it has too much foam in it. 25 seconds… Can’t believe its gone. It has to come back up unless it went deep enough and got caught on something… around 30 seconds it comes back up floating fairly level and the prop still spinning! Jumps on plane, scoots towards shore, hits the football sized rocks and makes a clean jump up the two foot high bank and lands upside down about 8’ into the yard upside down with the prop spinning. Then the motor shuts off. Huh?!?!? Hatch and tape actually held but it had some water in it which got into my Spektrum 3ch receiver and glitched it.
    Well, a scuff in the hull, a hair line crack in the gelcoat at one of the strakes and a bent brass stuffing tube. Nothing else wrong! Brass tube has been replaced and it is ready to go again.
    So, how the heck do you trim these little guys out? I am now thinking on how flighty this little cat is I should have bought a Velocity mono from Sailr. Dang impulse buys!
    I will have to post some pics and also try to get a video of it running. Going to try again today and see if I can get some calmer water.
    Brian
  • 6S HYDRO
    • 1325
    any piks of this thing? you got a full page describing the thing- i wanna see it
    • 6S HYDRO
      • 1325
      Only thing on ebay under sea rider is made out of legos's- is this a lego boat?
      • marko500
        • 862
        I also have one of the Velocity mini cats. I run it on a 3s 1500mah lipo. I trim it out by moving the battery fore or aft. The steering servo, esc are on the right (starboard) side,the receiver is in the left (port) rear corner and the battery is in front of that. Mine will hop a little starting out but once its up to speed she flattens right out. As stated 2" chop is pretty big for that size boat, I think it will hop no matter what you do in those conditions. I don't use the plastic sheet cover instead I just tape the hatch down, someone said this helps to self right the hull a little bit. Shes gone over but ends up right side up a little better than 3/4 of the time. My sons and I love this little boat!
        • 6S HYDRO
          • 1325
          Its not a velocity its a sea rider? Cant find this
          • marko500
            • 862
            I've seen them on ebay but have been looking and can't find one either. the Velocity at Mini Cat Racing looks the same but supposedly uses some better components. I know that there is a place up in Toronto Canada and someone in Australia that sells or used to sell the sea rider version.
            • befu
              • Aug 2009
              • 1064
              Pictures
              This isn't the lego forum!?!?! No wonder all these boats look fantastic!!! I been searching for these custom pieces for weeks!!!!!!
              Sorry, didn't mean to cause such a visual impaired problem!!!
              It appears the seller is not listing any right now on Ebay. They still have the mini V for the same price. Seller is RChobbydepot
              A few pics of the hull from the ebay add:
              As mentioned, I changed the stuffing tube so it is brass all the way to the strut. Removed the turn fins. Also removed the antenae as I have the 2.4 Ghz.
              I also filled the canopy with foam. Another thing I did was to silver solder the end of the flex cable where it goes into the motor coupler.
              Oh, that and the scratch on the bottom!
              brian
              • befu
                • Aug 2009
                • 1064
                ran again
                OK, ran it for the 3ird time now. Moved the battery forward a bit. Water was a little calmer, still kinda wavy.
                Well, it did do a little better, but still hoping bad and pushing the nose to high. Ended up flipping it after a couple of minutes and had to go take it in. while opening it up to move the battery further forward, a drop of water came off the hatch and right into the reciever, glitching again
                After that, the wind died and the water got nice and calm
                I can't win. So I will try again later.
                The hardware is nice, motor runs great. Might end up building a WOF cat hull and put it in that. Either that of a scale offshore hull. We will see, more runs needed.
                I think I will go play with legos now......
                Brian
                • crabstick
                  • 955
                  cool little cat.
                  that would go well in the ponds at the golf course!
                  Matt.
                  www.rcboats.co.nz
                  • marko500
                    • 862
                    You are going to need to waterproof the receiver. Everybody has their favorite method. I just use a condom (I made sure to tell my wife what I used them for before she found them in my tool box and started to wonder about all the time I spend at the pond) Keep the receiver dry and thats one less thing to worry about or lose a boat over. Think its fun on 2s ,if its rated for it you should try it on 3s sometime!
                    • befu
                      • Aug 2009
                      • 1064
                      more information on sea rider
                      yeah, I will wrap the receiver. Below are a couple of pics of my boat. The one shows the brass stuffing tube added. The other is of the bottom ride pad, trying to show the slight hook.
                      Pictures not uploading right now, will add them later.
                      Brian
                      • crabstick
                        • 955
                        your best bet is to coat the receiver with DP270 epoxy, available from OSE.
                        it will then run underwater if you ever feel the need
                        Matt.
                        www.rcboats.co.nz
                        • bustitup
                          • 3072
                          just a heads up:
                          there is one of these for sale at rc universe for $130...its red and white
                          brian
                          • befu
                            • Aug 2009
                            • 1064
                            4th run
                            I remember seeing one for sale right after I ordered mine - that is how it works. Can't find it now.
                            well, just tried the 4th run. How come when I leave work, the flags are hanging limp, no movement. But when I get to the pond, thier is a stiff breeze breaking the surface?
                            Still pretty calm this time, moved the battery another 1/2" or so forward and the COG is now 5" from the transom, or 32% of hull.
                            Ran better, but only had about 3 minutes to run before I had to get home! Actually drove it back in and didn't have to retrieve it. Will try to get out there this evening and get a video.
                            Boat ran well. Still corners great without the turnfins, plenty sharp. Sits right down, plants the outside sponson and carves a turn without hopping. Along the straights it is almost dialed in. It runs great until it reaches top speed and then you can hear it hopping as the prop comes out of the water. I will move the battery another 1/2" forward and see how it does.
                            Water is definately getting into the hull. Only 3 min of running, no wipeouts or flips but still a little water in the hull. Could be a leaking water line also, need to test it in the sink.
                            This boat is designed for 3 cells, but I have about 8 of the 2s-2200's so I am trying to run it on that. I do not want it to fast as I want my kids to be able to run it. Still not sure about that. You have to drive this thing, not just run it.
                            below are the pics I was trying to upload in the other post. One is the stuffing tube I added, the other is of the ride surface.
                            The only 3s I have is a 12c-1200 so not sure if it will work. I will try it, but only for a short burst as I am sure it will pull to much amperage for that battery.
                            • marko500
                              • 862
                              Mine was leaking water up the drive shaft. I put a short piece of cooling line part over the stuffing tube and part over the flex shaft. The piece is only about 3/8 to 1/2 inch long. Mine also leaked in around the rudder pushrod which you already fixed. I would post a picture but my son went camping this weekend and took my camera.
