"ETTI" Rigger (Demon) building directions
  • Dee
    • Mar 2008
    • 24
    Hi there,
    I knew somebody might be interested in this rigger but did not know how to build it, therefore I upload some assembled photos with data for you all reference!
    Maybe you will find the setup a little strange but you can build what like!
    Or you have your own mind to build it. No need to follow these building directions to assemble the Demon!
    These photos are only for a reference and I also would like to share our experience and experiment with all you guys.
    Hope this helps!
    Dee ^_^
  • Dee
    • Mar 2008
    • 24
    • Dee
      • Mar 2008
      • 24
      • Dee
        • Mar 2008
        • 24
        • Dee
          • Mar 2008
          • 24
          Another different building directions~
          • Ub Hauled
            • 3051
            I like this little Demon....
            • Dee
              • Mar 2008
              • 24
              One more different built Demon:
              Enjoy~
              • Ub Hauled
                • 3051
                How much does it weight as a bare hull + installed sponsons Dee?
                • Dee
                  • Mar 2008
                  • 24
                  Do I count the hardware as well?
                  If not, the weight would be around 385 gram~
                  • Ub Hauled
                    • 3051
                    no hardware is fine, I was just trying to get an idea...
                    • Ub Hauled
                      • 3051
                      Does it come with the motor mount? If so, does it have a hole pattern for NEU motors?
                      • Dee
                        • Mar 2008
                        • 24
                        Yes, it does come with motor mount and fits for "NEU" 11XX & 15XX series and our "ETTI" B29 & B36 series (380 to 540 size) motor (with 19mm to 25 mm motor mounting holes)~
                        See pic.
                        • Ub Hauled
                          • 3051
                          excellent Dee!!!
                          • 6S HYDRO
                            • 1325
                            The first one has unsupported teflon running to the strut?
                            • Dee
                              • Mar 2008
                              • 24
                              Yes, there is not a problem without mounting stuffing tube for supporting the telfon tubing and flex cable.
                              That .130 telfon is fitted for inserting into the cone of the our ETTI strut, no need to insert extra stuffing tube.
                              Without stuffing stub, it is easier to adjust the strut angle than having stuffing tube for running!
